RGB Channels
This page is in process of being revised.
Introduction to RGB
Adding RGB Channels
Another example when this may come in handy is when you have imported a sequence from Vixen or LOR which contains three separate RGB channels that you now want to combine into one.
To convert three R, G, B channels into one:
- Verify that the three channels you wish to convert are setup properly. (See Figure)
- Open the Converter for RGB (Click Manage Channels -> Auto Convert Channels to RGB. (See Figure)
- Place the Red Channel in Red, Green Channel in Green, and Blue Channel in Blue. (See Figure)
- A dialog will open with information about how many channels have been converted. (See Figure)
- Open HLS and open the Channel Manager to see the newly converted channel(s). (See Figure)
- Click OK.
Channel Reduction
RGB can also be used to program non-RGB lights to reduce the number of channels by 2/3. For example, imagine a Mega tree with 16 strings red, white and blue lights (48 strings total). Each RGB channel could represent 3 outputs, red, white, and blue. When programming, if red is chosen for the effect the red lights would be on. When green is chosen for the effect the white string would be on, when Blue is chosen blue would be on. If white is chosen for the effect color, all three would be on.
Advanced Channel Management | Chapter 3: Channel Management | Configuring Display Groups |
