Creating Basic Effects
Based on Version 11V.
The HLS Sequencing Window has four basic components which are important when sequencing (See Figure 5-1).
- The Undo Last Effect button removes the last effect applied.
Selection Mode in HLS
Basic Method to Create a Selection Box:
Basic Effects
![](/wiki/images/thumb/6/69/HLS_TimingGrid_BasicEffects_11V.png/300px-HLS_TimingGrid_BasicEffects_11V.png)
Level:
- Shortcut key: L
Ramp Up:
- Shortcut key: U
Ramp Down:
- Shortcut key: D
Modifying Effects
Moving Effects:
Deleting Single Effects:
Deleting an Area of Effects:
Copy/Paste Effects:
- Select the effect you wish to copy by CTRL Left-Clicking the left-most cell to copy. (This lets HLS know that you are wanting to select cells rather than move the effect.)
Modify Effect Attributes:
![](/wiki/images/thumb/1/1a/HLS_ModifyEffect_11V.png/300px-HLS_ModifyEffect_11V.png)
Chapter 4: Display Preview | Chapter 5: Sequencing Channels and Adding Effects | Adding and Using Beat Tracks |
