Adding and Using Beat Tracks
This is based on version 11V.
HLS supports creating beat tracks in a couple of ways.  One way is to manually press a button or click a mouse while a song is playing to set the beat.  Another way would be to apply a filter to the audio and then manually "turn on" the beat track at points identified through the filter.
Add Beat Track Channels
First, channels must be added so you can use them as beat tracks.
Setting Display Group for Beat Track
 - Create a Display Group named "Beat" and add all three channels (See Figure 5-6).
Beat Track From Clicks
Creating a Beat Track from Clicks is one of the easiest ways to create a Beat Track. Clicks must be quick and not everything will line up perfectly, but it can give reasonably good results.
- Activate the Beat Track by clicking Manage Channels -> Select a Beat Track Channel.
 - Select the Beat Track you want to use and click OK (See Figure 5-7).
- Check the box Beat Track Active to let HLS know that you are planning to record clicks for a beat track (see Figure 5-8).
 - Press the CTRL key or the Left Mouse' button at each beat in the song.
- When the song is complete, there will be two grid cells filled in at every click received. Your beat track has been created. (See Figure 5-9)
Beat Track from Filters
Section needs to be completed. Filling in squares for beat track.
This is a very powerful feature of HLS and one that can come in handy when setting up beat tracks.
- Wikipedia: High Pass Filter
- Wikipedia: Low Pass Filter
 - Band Pass filter: This filters on BOTH high and low frequencies.  The Frequency value is the "desired" frequency.  A band pass filter will filter OUT both the high and low frequencies that are further away from that frequency.
- Wikipedia: Band Pass Filter
Common Frequencies:
Cleaning up a Beat Track
 - When the timing mark is placed where you want it, click on it again (or press escape) to exit selection mode.
