Importing a Sequence from Vixen
Current as of Version 12E.
- Open HLS and click on the Audio File menu and then select Add Wav or MP3 File to This Sequence.
 - Select your audio file and after it is loaded, click on the I’m Done Return button.
 - Under the File menu, select Import a Vixen File. – You will be prompted to select the VIX file.
 - Select the VIX file you would like to convert. Note that the HLS conversion will give the new HLS file the same name as your VIX file with different extensions. You may see a note about HLS making a slight timing adjustment to the VIX timing to make it more exact.
 - Select OK, The conversion will take place and you will see a note showing that the channels have been converted. This may take some time.
 - After the conversion you can choose the Manage Channels menu, select channels to create a group and work like you normally would with HLS.
Note: See the beginning of this document to see how to program in HLS.
