Creating a PixelPlane
This documentation is incomplete.
Current as of Version 12C.
What is a PixelPlane?
How to Create a PixelPlane
![](/wiki/images/thumb/0/01/HLS_PixelPlane_SpecifyYourPixelPlane.png/300px-HLS_PixelPlane_SpecifyYourPixelPlane.png)
![](/wiki/images/thumb/d/de/HLS_PixelPlane_PixelPlaneObject.png/300px-HLS_PixelPlane_PixelPlaneObject.png)
- Assign the type of PixelPlane that you have and then click "Assign Type of PixelPlane."
- Note:As of version 12H, only type "Mega Tree" is currently supported.
- Complete the fields to help HLS understand your PixelPlane object, then click OK (See Figure 6-4).
In development.
Working With a PixelPlane
- Just like with any channels, you must assign a PixelPlane to a Display Group to be able to work on it.
- Click Manage Channels -> Select Channels and Assign to Display Group.
- Do not add all of the pixel channels to the display group. ONLY add the PixelPlane channel. (See Figure)
- Then, set the Display Group to the PixelPlane group to begin working on it. It will show as a single channel. (See Figure)
Like any RGB channel, PixelPlane channels can have effects placed on them.
HLS has a built in PixelPlane Effect Editor, which can generate PixelPlane Effects.
HLS also supports dropping in effects from third parties, such as Nutcracker effects.
Chapter 5: Sequencing Channels and Adding Effect | Chapter 6: The PixelPlane | The PixelPlane Editor |
