Importing and Exporting CSV
To aid in mass channel configuration and changes, HLS allows the user to export channel information to CSV (Comma Separated Values). This is a common text-based data export that can be imported in various programs, such as Excel. This exported data can then be viewed in another program, modified, and then imported back into HLS.
- Some potential uses for this feature include:
- Adjusting channel information
 - Creating new channels
 - Printing channel information
Exporting Data to CSV
- To export your channel data, open the channel manager (Manage Channels -> Manage Raw Channels).
 - In the bottom-right of the window, click Export CSV File (see Figure 11-4).
 - A window will open confirming that the export is complete (see Figure 11-5).
 - The location of the exported file will be inside the HLS folder for the sequence you exported information from.
- Ex.: Channel info exported from a sequence named "Carol". Go into the HLS/Carol folder and the exported file will be named Carol Export.csv.
Working With Exported Data
- Note: For this example, Excel will be used, but any program that can manipulate CSV files will work.
 - Open the exported file in Excel.
 - The Channel information will be listed in column format with headings explaining what each column value is for (see Figure 11-6).
- Guid: This is a unique identifier given by HLS for that channel.
 - Current Name: The current name of the channel.
 - Universe: DMX Universe the channel is assigned to.
 - Channel: Output channel assignment.
 - RGB: Boolean value (0 or 1) for whether the channel is RGB.
 - Prev Group: Preview Group assignment.
 - Prev Number: Preview Group Number.
 - New Name: This field is used by HLS when channels are being renamed.
 - Make desired changes Excel. Know that HLS is unable to apply any error-correction for values you put in here since you are modifying it outside of HLS.
 - If you add channels, you will not have a GUID. HLS will assign this on import.
Importing CSV Data Into HLS
- Once changes have been made, save the CSV file.
 - Go ahead and save your HLS sequence in case there is a problem with the import.
 - Click Manage Channels -> Import CSV and Update Raw Channels.
 - You will be prompted with a warning about saving your sequence. Click YES since you have already saved (Or click NO and save now).
- There are two ways to import the data (see Figure 11-7):
- Import based on GUID: Import and use the GUID when making changes to channel data.
 - Import based on Current Name: Ignore the GUID field on import and copy any changes based on the Current Name field.
- Specific actions to take with the imported data:
- Replace Current Name with New Name: The "original" name of the channel will be replaced with the one you have entered into "new name".
 - Replace Universe Number: Overwrite old DMX Universe number with data from CSV.
 - Replace Channel Number: Overwrite old Output Channel number with data from CSV.
 - Replace Preview Group: Overwrite old Preview Group number with data from CSV.
 - Replace Preview Number: Overwrite old Preview Number with data from CSV.
- Once you have made the selections you need, click OK.
 - Select your CSV file to import from and click open.
 - HLS will now import the CSV data and will let you know how many matches were made, then save your sequence.
- Important: If you create NEW channels in CSV, you MUST FIRST create empty channels in the raw channel manager so HLS has a place to move that data into the sequence. If you do not do this, the data from those new channels will not be imported.
| Using HLS Sequence Images | Chapter 11: Importing and Exporting Data and Sequences | Importing a Sequence from Vixen |
