Creating a Sequence-Test
Setting up the Sequence File:
![Figure 0-1](/wiki/images/thumb/8/8d/HLS_MenuSelect_SequenceWizard.png/275px-HLS_MenuSelect_SequenceWizard.png)
![](/wiki/images/thumb/2/2a/HLS_SequenceWizard_MusicFilePrompt.png/300px-HLS_SequenceWizard_MusicFilePrompt.png)
![](/wiki/images/thumb/b/bd/HLS_SequenceWizard_FolderCreationPrompt.png/300px-HLS_SequenceWizard_FolderCreationPrompt.png)
![](/wiki/images/thumb/0/07/HLS_SequenceWizard_NameSequence.png/300px-HLS_SequenceWizard_NameSequence.png)
![](/wiki/images/thumb/f/f9/HLS_SequenceWizard_ReadyForAudio.png/300px-HLS_SequenceWizard_ReadyForAudio.png)
Setting up the Audio File:
![](/wiki/images/thumb/c/c8/Acquire-Wav-File-HLS.jpg/300px-Acquire-Wav-File-HLS.jpg)
![](/wiki/images/thumb/c/cf/HLS_SequenceWizard_AudioSelect.png/300px-HLS_SequenceWizard_AudioSelect.png)
![](/wiki/images/thumb/0/0f/Audio_file_confirmation.jpg/300px-Audio_file_confirmation.jpg)
![](/wiki/images/8/88/SaveComplete.jpg)
Chapter 1: Getting HLS | Chapter 2: Creating a Sequence | Time Resolution |
