Adding and Using Beat Tracks
HLS supports creating beat tracks in a couple of ways. One way is to manually press a button or click a mouse while a song is playing to set the beat. Another way would be to apply a filter to the audio and then manually "turn on" the beat track at points identified through the filter.
Add Beat Track Channels
![](/wiki/images/thumb/8/8b/HLS_BeatTrack_AddChannels_11V.png/350px-HLS_BeatTrack_AddChannels_11V.png)
First, channels must be added so you can use them as beat tracks.
Setting Display Group for Beat Track
![](/wiki/images/thumb/2/2d/HLS_BeatTrack_AddDisplayGroup_11V.png/350px-HLS_BeatTrack_AddDisplayGroup_11V.png)
- Create a Display Group named "Beat" and add all three channels (See Figure 5-6).
Beat Track From Clicks
Creating a Beat Track from Clicks is one of the easiest ways to create a Beat Track. Clicks must be quick and not everything will line up perfectly, but it can give reasonably good results.
![](/wiki/images/4/4e/HLS_BeatTrack_SelectBeatTrackChannel_11V.png)
- Activate the Beat Track by clicking Manage Channels -> Select a Beat Track Channel.
- Select the Beat Track you want to use and click OK (See Figure 5-7).
![](/wiki/images/thumb/9/96/HLS_BeatTrack_BeatTrackActive_11V.png/350px-HLS_BeatTrack_BeatTrackActive_11V.png)
- Check the box Beat Track Active to let HLS know that you are planning to record clicks for a beat track (see Figure 5-8).
- Press the CTRL' key or the Left Mouse button at each beat in the song.
![](/wiki/images/thumb/8/81/HLS_BeatTrack_ClickTrack_11V.png/350px-HLS_BeatTrack_ClickTrack_11V.png)
- When the song is complete, there will be two grid cells filled in at every click received. Your beat track has been created. (See Figure 5-9)
Beat Track from Filters
This is a very powerful feature of HLS and one that can come in handy when setting up beat tracks. You get to this by clicking Audio File -> Apply Lo or Hi Pass Filter or Band Pass. The DSP Filtering window will open (See Figure 5-10).
![](/wiki/images/thumb/2/28/DSP-Filtering.png/350px-DSP-Filtering.png)
- Wikipedia: High Pass Filter
- Wikipedia: Low Pass Filter
- Band Pass filter: This filters on BOTH high and low frequencies. The Frequency value is the "desired" frequency. A band pass filter will filter OUT both the high and low frequencies that are further away from that frequency.
- Wikipedia: Band Pass Filter
Applying the Filter:
![](/wiki/images/thumb/6/60/HLS_BeatTrack_NormalAudio.png/350px-HLS_BeatTrack_NormalAudio.png)
![](/wiki/images/thumb/5/56/HLS_BeatTrack_DSPFilter.png/350px-HLS_BeatTrack_DSPFilter.png)
- Choose the filter you wish to use, enter the needed information, and click OK. You can also use the "Stay Here" option to apply the filter and continue working with the audio without closing the Filtering window. (See Figure 5-11a and 5-11b for an example of the audio before and after applying an 8 khz filter to attempt to isolate a cymbal sound.)
![](/wiki/images/thumb/4/46/HLS_BeatTrack_2.png/350px-HLS_BeatTrack_2.png)
- Once the sound has been isolated, manually add effects where the sound is present. In the example, Beat Track 2 is being used to mark two cells with a Level effect at each cymbal sound (see Figure 5-12).
- Tip: To speed up this process, you may find that using the CLICK filter AFTER applying the DSP filter will allow you to click accurately with the sound you want isolated rather than manually drawing in the effects.
- Once finished with the filter, return the audio to normal by choosing Audio File -> Remove Filter.
Common Sound Frequencies:
Cleaning up a Beat Track
- When the timing mark is placed where you want it, click on it again (or press escape) to exit selection mode.
Creating Basic Effects | Chapter 5: Sequencing Channels and Adding Effects | Setting Defaults for Effects |
