FM02 Gallery
Pictures of Various FM02 and other VAST product Installations . . . . . . Click on the pictures !
By OregonLights.
FM02
By OregonLights.
FM02
By Underdog.
FM02
By Underdog.
FM02
By CaptKirk.
FM02
Mounted in an Aluminum case -
By chelmuth.
FM02
By chelmuth.
FM02
By smartalec.
FM02
By RobDude30.
FM02
By RobDude30.
FM02
By rkhanso.
FM02
By rkhanso.
FM02
By klanger.
By AURBO99.
By AURBO99.
By imbluenote.
By kingofkya.
By dmcole.
1 Watt VAST unit
By rogelio.
FM02 with MicroRDS unit
By rfallatt
FM02
By rfallatt
FM02
By rfallatt
FM02
By SamJ435.
By SamJ435.
By pcoshatt
FM02
By pcoshatt
FM02
By hasoon
FM02 with Wall Wart Tamer
By hasoon
By jduawa
FM02
By jduawa
FM02
By Howards9
FM02
By Howards9
FM02
By idleup
FM02
CableGuard CG-1000 Demarcation Enclosure Customized for FM-02 transmitter and accessories with power switch assembly SLM2596 Buck Converter Step Down Power Regulator and Conditioner (3v to 40v) BH1415 Sound Quality Improvement Modification (modifies 19Khz pilot tone level to reduce hum and improve sound quality) Wall Wart Power Pack (I used one from an old dust buster, the SLM2596 will allow you to use any adapter 3v to 40v for your input power) -
By idleup
FM02
By nuelemma
FM02 front
A project box installation -
By nuelemma
FM02 back
