Soldering Basics
Soldering quick tips
The best solder joints come from a combination of good solder, good tools and practice. A good solder like Kester 44 (use 63/37 with flux core and 0.032" diameter 1/2lb spool for starters) along with a good temperature controlled soldering like the CSI 1A, CSI 3DLF or the Tenma 21-10115 will result in good solder joints. For under $10 you can buy a lot of spare parts and pcbs to practice on listed below |
Solder Types
Electronic Solder
- Lead/Tin solder
- "Silver" solder
- Lead-free solder
Lead/Tin
Lead/Tin solder is available in different mixtures of the two metals. There are two popular mixtures available:
*63/37 (Called a eutectic mixture) It contains 63% Tin and 37% Lead and melts exactly at 183 °C (361 °F)
*60/40 Is a common solder that contains 60% Tin and 40% Lead and melts over a range of 183–190 °C (361–374 °F)
They both work fine for electronic work. It is a personal choice as to which you use. The main difference is how they both cool. The 60/40 when cooling goes through a "slushy" phase and does not always result in a bright shiny joint. The 63/37 eutectic solder cools quickly and does not go through the slushy phase. Many people prefer the 63/37 solder, but will use whatever is available when they have it!
Care should be used when handling Lead based solders, you should always wash your hands when you are finished soldering and before eating. In practice there are very low levels of lead in the smoke from soldering, so it is a good idea to not inhale the smoke. You should also not put the solder in your mouth or chew on it....
"Silver" Solder
Silver solder is similar to Lead/Tin solder, but has a small amount of silver (2-4%) added to it. It is more expensive and is not commonly used for printed circuit board work. It is a specialty solder sometimes used for parts that are already silver plated. The common silver solder eutectic mixture that is 62% Tin/36% Lead/2% Silver melts at 179 °C (354 °F). There is also a "Hard Silver Solder" that has 80%Silver in it and it is used for soldering jewelry and not electronics.
Lead Free Solder
Lead free solder became popular in Europe on July 1, 2006 due to environmental laws associated with eliminating lead. It is generally not recommended for printed circuit board soldering by hobbyists. It is harder to get a good solder joint and is only used by manufacturers using special tools and processes.
Solder Forms
Solder Wire
Solder Paste
Solder paste is a gel that is a mixture of lead/tin solder and flux in a paste form. It is commonly used when attaching a surface mount device (SMD) to a printed circuit board. It is usually dispensed through a syringe with a needle tip. Solder paste has a relatively short shelf life of a few months, and should be stored in a refrigerator when not being used. It is typically smeared across the fine copper traces and the part placed on top of it. When the paste is heated up using either hot air or a soldering iron, the paste melts and is drawn to the metal legs and traces.
Bad Solder
Lead Free Solder
Lead Free solder has its roots in Europe due to certain restrictive environmental regulations. It requires greater heat and is noticeably harder to get a good hand soldered joint compared to lead/tin solder. Lead Free solder is often sold right next to regular lead/tin solder in stores, so be careful when you buy your solder. BEGINNERS AND CASUAL USERS SHOULD AVOID LEAD FREE SOLDER. If it is the only solder available, it can be used with caution. For tips on using lead free solder read this article. It generally comes in two compounds Tin/Copper called SnCu or Tin/Silver/Copper (96.5% Tin, 3.0% Silver, 0.5% Copper) called SAC.
Stained Glass Solder
Flux
Soldering Irons
Temperature Controlled
Low Cost Uncontrolled
Soldering Guns
Soldering Tools
Desoldering
Solder Suckers
Solder Braid
Tweezers
Holders
3rd Hand
Board Holders
Painters Tape
Magnifying Glass
Tip Cleaner
Hand Tools
Fume Extractor
Flux Remover
How to Solder
Preparation
Iron Temperature
Soldering technique
How to Desolder
How To Solder Videos
How To Solder Guides
Solder and soldering articles
Vendors
Hobby KingSoldering irons
Kester Solder Solder
Soldering Practice
Description | SKU | Quantity |
Small StripBoard 94x53mm (Copper) | A-5031 | 2 |
Big StripBoard 110x93mm (Copper) | A-2384 | 1 |
Prototyping Board 142x74mm | A-5052 | 1 |
8 pin DIP IC Socket Adaptor Solder Type | A-001 | 4 |
14 pin DIP IC Socket Adaptor Solder Type | A-004 | 4 |
6 pin DIP IC Socket Adaptor Solder Type | A-624 | 4 |
680 OHM 1/4W 5% Carbon Film Resistor | A-2075 | 20 |
1K OHM 1/4W 5% Carbon Film Resistor | A-624 | 20 |
0.1uF 50V Multilayer Monolithic Ceramic Capacitor | A-214 | 5 |
LED 5mm Red Super Bright | A-1554 | 5 |
BTA06-600C BTA06-600 Triac 600V 6A | BTA06-600C | 1 |
1N4004 Diode 1A 400V | A-156 | 4 |
DG301 Screw Terminal Block 2 Positions 5mm | A-668 | 3 |
IRLU024 MOSFET 65 mOhm 17A 55V N-channel I-PAK-3 IRLU024NPBF | A-1453 | 1 |
LM7805 L7805 7805 Voltage Regulator IC 5V 1.5A | A-179 | 1 |
40 Pin 2.54mm Single Row Pin Header Strip | A-197 | 1 |
47uF 16V 105C Radial Electrolytic Capacitor 5x11mm | A-4522 | 5 |
