10W-RGB-LED-DRIVER
It has the ability to drive a 10W RGB LED via a 5v DC PWM signal that will therefore allow
As a separate 12V power source is applied to the board, three different connections are made to the board that can
10W RGB LED
This board was specifically designed for a commonly found 10W RGB LED.
Color: RGB
Beam Angel: 140 degrees
Life span: >50,000 hours
less than 1" square.
The BOM for this board uses both Surface mount(smd) and through-hole components.
The board can use either through-hole or smd inductors.
BOM for 12V DC power input:
QTY Board ID Description 3 IC1,IC2,IC3 PT4115 by Powtech: 30V, 1.2A Step-down High Brightness LED Driver with 5000:1 Dimming 3 L1,L2,L3 100uH Inductor, 6x8mm, 700ma 3 T1,T2,T3 Transistor FJN3314R 3 D1,D2,D3 Diode 1N5819 3 R1,R2,R3 Resistor, 1/4 Watt, 0.33 Ohm 3 R4,R5,R6 Resistor, 1/4 Watt, 4.7K (4K7) Ohm 1 IC4 Voltage Regulator, 5V 78L05 1 C1 Electrolytic Capacitor 100uF 35v (polarized) 1 C2 MLCC Ceramic Capacitor .1uF 50v (monolithic)Leaving out the LED Channel Indicators
I don't want the LED Indicators !
If you don't want to install the LED indicators, that is just fine, the board was designed to accommodate that wish. However, you do still need to install the resistors; BUT they need to go in different holes and have a different resistance value. You will need to use a 680 ohm resistor instead of the 220 ohm resistor. You would install this resistor with one lead in the top most resistor hole and then have it span the space down to the bottom most LED mounting hole.How to use LEDs of many colors for the Channel Indicators
The board was designed and silkscreened to use a 220 ohm resistor and red LED for the the channel indicator. However, other colors can be used. Red LEDs have a typical forward voltage (Vf) of 2.0 volts. However, other colors, like green, have a Vf of 3.x volts. Therefore, if you use a LED with a Vf in this range, you should replace the 220 ohm resistor connected to that LED with a 180 ohm resistor. The basic equation is:
V(supply): Supply voltage, in our case 5V
Vf(opto): Forward voltage of the opto emitter, 1.5V max, 1.15 typ
Vf(LED): Forward voltage of the LED, for the LEDs I use it is 2.0V
Vol: Low voltage output level, For the purposes of this calculation, a value of 0.33V max, 0.18V typical was used.
If you are concerned about the current draw then you can increase the value of R based on the typical values (i.e. to either 270 or 300). However, there is a concern that with the temperature extremes these devices are used in, this would push them closer to the max values and cause erratic behavior.Construction Information
There are several 'how to build a PCB' self help guides both within this wiki and the web. Here is a picture of a completed SSRneon-G2: (The fuse cover has been removed)Wiring The SSRneon
Controller Output Pinout
