10W-RGB-LED-DRIVER
![Version G2](/wiki/images/8/86/10W_RGB_Driver_Top.jpg)
10W RGB LED
![small](/wiki/images/9/96/10W_RGB_LED_smaller.jpg)
Color: RGB
Beam Angel: 140 degrees
Life span: >50,000 hours
less than 1" square.
![Version G2](/wiki/images/c/c5/10W_RGB_Driver_Bottom.jpg)
BOM for 12V DC power input:
QTY Board ID Description 3 IC1,IC2,IC3 PT4115 by Powtech: 30V, 1.2A Step-down High Brightness LED Driver with 5000:1 Dimming 3 L1,L2,L3 100uH Inductor, 6x8mm, 700ma 3 T1,T2,T3 Transistor FJN3314R 3 D1,D2,D3 Diode 1N5819 3 R1,R2,R3 Resistor, 1/4 Watt, 0.33 Ohm, 5% or better, carbon or metal film 3 R4,R5,R6 Resistor, 1/4 Watt, 4.7K (4K7) Ohm, 5% or better, carbon or metal film 1 IC4 Voltage Regulator, 5V 78L05 1 C1 Electrolytic Capacitor 100uF 35v (polarized) 1 C2 MLCC Ceramic Capacitor .1uF 50v (monolithic)
Assembly Tips
![Version G2](/wiki/images/a/a5/10W_non_groupby_version_builtup.jpg)
Mounting the LED:
Soldering Sequence
Wiring examples
General Notes
REN48LSD connections
![](/wiki/images/thumb/f/fa/10W_RGB_REN48lsd_hookup_diagram.jpg/300px-10W_RGB_REN48lsd_hookup_diagram.jpg)
Installation examples
![](/wiki/images/thumb/7/78/10W_flood_installation_by_livermore_dad.jpg/300px-10W_flood_installation_by_livermore_dad.jpg)
![](/wiki/images/thumb/f/fd/10W_schematic.png/300px-10W_schematic.png)
