10W-RGB-LED-DRIVER
![Version G2](/wiki/images/8/86/10W_RGB_Driver_Top.jpg)
10W RGB LED
![small](/wiki/images/9/96/10W_RGB_LED_smaller.jpg)
Color: RGB
Beam Angel: 140 degrees
Life span: >50,000 hours
less than 1" square.
When using this LED with the 10W Driver board, you need to remove the bar along the anodes that tie them together.
Do NOT snip the anodes themselves off. Just the linking bar. When you are done, both sides of the LED should look the same.
![Version G2](/wiki/images/c/c5/10W_RGB_Driver_Bottom.jpg)
BOM for 12V DC power input:
QTY Board ID Description 3 IC1,IC2,IC3 PT4115 by Powtech: 30V, 1.2A Step-down High Brightness LED Driver with 5000:1 Dimming 3 L1,L2,L3 100uH Inductor, 6x8mm, 500ma 3 T1,T2,T3 Transistor FJN3314R 3 D1,D2,D3 Diode 1N5819 3 R1,R2,R3 Resistor, 1/4 Watt, 0.33 Ohm, 5% or better, carbon or metal film 3 R4,R5,R6 Resistor, 1/4 Watt, 4.7K (4K7) Ohm, 5% or better, carbon or metal film 1 IC4 Voltage Regulator, 5V 78L05 1 C1 Electrolytic Capacitor 100uF 35v (polarized) 1 C2 MLCC Ceramic Capacitor .1uF 50v (monolithic)
Assembly Tips
![Version G2](/wiki/images/a/a5/10W_non_groupby_version_builtup.jpg)
Mounting the LED:
Soldering Sequence
The trick to soldering these little fellows are to:
1. Use some liquid flux on the pads
2. Use a fine, clean, tip on your soldering iron
3. Use VERY LITTLE SOLDER ! A fine gauge solder would be helpful
You should concentrate on tacking down one of the the outermost pads (not the center pad) to hold the IC in place.
Once you do this, the rest will be much easier.
Wiring examples
Note !! This section is under assembly and will be greatly expanded
General Notes
REN48LSD connections
![](/wiki/images/thumb/f/fa/10W_RGB_REN48lsd_hookup_diagram.jpg/300px-10W_RGB_REN48lsd_hookup_diagram.jpg)
Testing & Trouble Shooting your board
After your initial build, you can test your board with a 12V DC input and a jumper wire.
Here is a link to a YouTube Video that shows this test.
Initial test video
Sometimes, you will solder everything, but find that one color isn't working.
The most common reasons for missing color:
Floating IC pin. Inspect each pin to make sure it is properly soldered.
Wet pins. Sometimes flux will stay under the IC and will conduct just enough current to prevent IC from working correctly.
Touch each pin with soldering iron for ~2-3 seconds... or just wait an hour or 2.
Resin from the core of the solder: Some resins will conduct, so clean all remaining resin with rubbing alcohol.
Shorted pins. Little droplets of solder can get stuck between pins (sometimes hidden by resin.)
Wet with flux and touch with iron for ~2 sec. On occasion, solder will get under the IC.
In that case, you can try flux several times and if that doesn't help, just desolder the IC.
HOWEVER, Desoldering the IC may damage PCB, so skillet, oven or hot air is the best method.
Here is another experience on how to fix initial trouble with a board:
I built ten boards. Four did not work originally. Three were solder issues with the PT4115. I fixed these by using a cue tip to add flux to both the PT4115 and solder wick and using a clean tip draw excess solder off the PT4115. They looked fine but this worked on three of the problem boards. On the fourth board I powered it on and then using a jumper cable started working backwards from the led. Turned out that I had a cold solder joint on the zener diode. Re-flowing from the bottom of the board did not fix it. I had to do a re-flow from the top.
Installation examples
![](/wiki/images/thumb/7/78/10W_flood_installation_by_livermore_dad.jpg/300px-10W_flood_installation_by_livermore_dad.jpg)
![](/wiki/images/thumb/0/0d/10w_brd_mounted.jpg/300px-10w_brd_mounted.jpg)
Click here to download the schematic as a pdf: File:10w fjn5 sch-1.pdf
![](/wiki/images/e/e9/10W_board_xray.png)
Where can I get one of these wonderful boards?
