ESPixel Stick & ESPixel Pops
Version V2
Version V2
The genesis of the pixel stick controllers started with designs by Bill Porter. You can read about this at Bills website found at: The mind of Bill Porter
The ESPixel Pops is the most basic of the Pixel Stick designs. It is a fully through hole PCB with no smd(surface mount) components. Therefore, it is easily built by most anyone with basic soldering skills. This variation was created by Pops Jones (ukewarrior) in order to create a form factor that would fit inside a 1" thin wall PVC tube.
small
small
5. The board is small enough to fit inside a 1" thinwall PCB pipe with the board measuring only 24.18x33.32 mm. This type of pipe is listed as SDR-21. Lowes example: Thin all 1" PCV pipe
Order your own boards
- Two 1/8W or 1/4W carbon film or metal film resistors. 330 Ohms. - One polarized Electrolytic capacitor. Any value from 10uF to 220uF will do. Pay special attention to the diameter and spacing of the leads. The diameter can be no more than 99mm and the leads should be spaced at 2mm.
- One Mosfet. This must be: 2N7000, which has a T0-92-3 style package
- A five pin screw terminal header. 5 positions total. This connection should have 3.81 spacing of the mounting pins.
Version V2
Version V2
Wiring The ESPixel Pops
You can either solder on a terminal block or directly solder your wires to the board, or do a mix ! The Terminal block has 3.81mm hole spacing. (The more common 5mm terminal blocks would have made the board too wide)
