ESPixel Stick & ESPixel Pops
Click Here:
Pixel Pops & Tiny
Order your own boards
Fuse Holder
5A Fuse
Click Here:
The BOM's are:
Mouser BOM is in Post #35
Arrow BOM is in Post #48
Digikey BOM is in Post #49
Wiring The ESPixel Pops
A Key Point Regarding Power
Programming the ESP-01 Module
