ESPixel Stick & ESPixel Pops
Version V2
Version V2
Version V2
Version V2
Version V2
Version V2
What is a Pixel Stick?
Pixel Pops & Tiny
Therefore, if you use the TINY board, you must have some other mechanism in order to program the ESP-01 module.
small
small
4. Supports up to 680 WS2811 or WS2812 Pixels - 4 Universes of DMX data 5. Supports up to 63 GECE Pixels 6. It supports both 5v and 12v pixels
Order your own boards
Fuse Holder
5A Fuse
Version V2
The BOM's are:
Mouser BOM is in Post #35
Arrow BOM is in Post #48
Digikey BOM is in Post #49
Wiring The ESPixel Pops
small
small
small
small
A Key Point Regarding Power
Programming the ESP-01 Module
--- under construction ---
