Pops-O-Matic ESP Programmer
Voltage Regulator
ESP Flashing Circuit
Pops-O-Matic Overview
1. 5mm Terminal Block
2. 3.5mm Terminal Block
3. Micro USB
4. Mini USB
5. Barrel Terminal Jack
Order a board
The BOM contains these generically described parts. The SKU at TAYDA electronics (www.taydaelectronics.com) is listed as a reference example following the silkscreen part identifier. Part U1 is not sold by TAYDA. A typical total for these parts is about $3-$4.
- ESP01 - ESP-01 module.
You can also order one off of TAYDA and is in the example BOM from noted below.
Errata
![small](/wiki/images/5/57/Pixel_pops_tiny_built_by_Steven_Dill.jpg)
There is an unwanted trace on the back of the board that connects the right most pin of part C5 to the ground backplane that covers the bottom of the board.
