Assembly Instructions The Renard SS16
Board Assembly
- The following sequence of steps is by no means the only way to assemble the Renard SS16. It is simply a suggested order of events to achieve the desired goal.
- NOTE: The part numbers referenced in the following instructions are those taken from the Renard SS16 BOM.
Triac Heat Sink
Parts Listing (BOM)
IMPORTANT BOM INFORMATION:
QTY | REF | NOMENCLATURE |
511-LF50CV | 1 | U1 | 5 VDC Voltage Regulator |
532-577102B00 | 1 | Heatsink for Voltage Regulator | |
782-H11AA1 | 1 | U2 | Optocoupler, Bi-Directional Input |
815-ACH-18.432-EK | 1 | U3 | Crystal Clock Oscillator, 18.432 MHz |
595-SN65LBC176P | 2 | U4, U5 | Differential Bus Transceivers |
571-1-2199298-2 | 2 | IC Socket, 8 pin (for U4 & U5) | |
579-PIC16F688-I/P | 2 | U6, U7 | PIC Microcontroller |
571-1-2199298-3 | 2 | IC Socket, 14 pin (for U6, U7) | |
859-MOC3023 | 16 | M1-M16 | Optoisolator, Triac Driver |
571-1-2199298-1 | 17 | IC Socket, 6 pin (for U2, M1-M16) | |
511-BTA06-600CW | 16 | T1-T16 | Triac, 6A 600V |
291-750-RC | 2 | R1, R2 | Resistor, Carbon Film 750 ohms 1/4W 5% |
291-120-RC | 1 | R3 | Resistor, Carbon Film 120 ohms 1/4W 5% |
299-1K-RC | 2 | R4, R7 | Resistor, Carbon Film 1K ohms 1/8W 5% |
299-27K-RC | 3 | R5, R8, R9 | Resistor, Carbon Film 27K ohms 1/8W 5% |
299-680-RC | 17 | R6, R10-R25 | Resistor, Carbon Film 680 ohms 1/8W 5% |
291-180-RC | 16 | R26 – R41 | Resistor, Carbon Film 180 ohms 1/4W 5% |
264-330-RC | 1 | RN1 | Resistor Network, 6 pin, 330ohms 2% |
511-1N5817 | 4 | D1-D4 | Diode |
78-1N5239B | 1 | D6 | Diode, Zener 9.1V .5W |
78-1N5229B | 1 | D5 | Diode, Zener 4.3V .5W |
604-WP710A10IT | 2 | FE, OE | LED, 3mm Red |
604-WP710A10GT | 4 | PWR, HB, ZC, SD | LED, 3mm Green |
140-REA222M1CBK1320P | 1 | C1 | Radial Electrolytic Capacitor 16V 2200uF 20% |
140-REA470M1CBK0511P | 1 | C2 | Radial Electrolytic Capacitor 16V 47uF 20% |
80-C322C104K5R | 2 | C3, C4 | Capacitor, Radial Ceramic 50V 0.1uF |
571-2828372 | 16 | Channel Terminals | Terminal Block, 2 Pos 5.08 mm |
571-7969492 | 2 | Power Terminals | Terminal Block, 2 Pos 5.08 mm |
152-3409 | 1 | JDP1 | D-Sub Connectors, Right Angle DE9 |
571-5556416-1 | 2 | J1, J2 | Jack, Modular RJ45 PCB Mount Top Entry |
538-22-03-2021 | 3 | JP1-JP3 | Header, 2 Pin |
806-SX1100-B | 3 | Shunt | |
504-BK/GMA-10-R | 2 | F1, F2 | Fuse, Fast Acting 10A |
534-3517 | 4 | Holder, Fuse Clip PCB mount 5mm | |
534-3527C | 2 | Cover, Fuse | |
838-3FS-312 | 1 | TF1 | Power Transformers 12.6VCT@.2A 6.3V@.4A Single Primary |
Hardcopy Instructions
