- You will need the free XCTU software from Digi International (www.digi.com) as well as an XBee programming board. An inexpensive programming board is available from SparkFun Electronics (www.sparkfun.com - XBee USB Explorer, SparkFun part # WRL-08687, about $25). Other programming boards are available and prices vary widely.
- 1. Verify that the programmer board is unplugged from the USB port, and plug the XBee module into the board.
- 3. Start the XCTU software. Choose the proper communication port into which the programmer board is plugged.
![](/wiki/images/thumb/0/0f/Xctu-1.JPG/300px-Xctu-1.JPG)
- 4. Use the default communication parameters to begin (9600 baud, no flow control, 8 data bits, no parity, 1 stop bit).
![](/wiki/images/thumb/4/41/Xctu-2.JPG/300px-Xctu-2.JPG)
![](/wiki/images/thumb/a/aa/Xctu-3aa.JPG/300px-Xctu-3aa.JPG)
- 8. Only four items need changing: PAN ID, MAC Mode, Interface Data Rate and Packetization Timeout (scroll down the XCTU screen to view more settings).
- PAN ID: this is akin to a "domain" for a computer network, but for XBee, the ID is numerical instead of text. The default is 3332 for all XBee modules, but you can change it to a different number if you wish or if another XBee network is in use nearby. Note that only modules with the same PAN ID can communicate with one another. (See PAN ID concept notes below)
![](/wiki/images/thumb/f/f3/Xctu-3d.JPG/300px-Xctu-3d.JPG)
![](/wiki/images/thumb/5/5d/Xctu-3c.JPG/300px-Xctu-3c.JPG)
