Ren-W Troubleshooting
- Be certain that the following components are mounted on the board properly:
- The zener diode (D1) has the black stripe on the TOP, next to the JP6 header pins.
- The 3.3 voltage regulator (U1) has the metal tab facing up, toward the JP2 header pins.
- If using an electrolytic capacitor for C1, C2, C4, C5 or C6, be sure its polarity is correct. The + sides are marked on the board; the opposite side it obviously the - side, which is marked on the capacitor itself.
- The LED (D2) while not very clear in this photo, has the cathode (flat side) facing the mounting hole to its right.
- Very few pins of the XBee radio modules are actually used; most are unused and serve only to hold the header pins securely.
- The solder pads for the XBee headers are very small; accurate and careful soldering is a must to prevent solder bridges. A solder bridge could easily prevent the XBee radio from functioning properly and could damage it.
- Note that the cat5 jacks J1 and J2 include additional solder pads for pins that don't connect to anything. These are provided for additional soldering area and strength in holding the jacks to the board.
- Easy Mistakes to Make
- Plugging the XBee module into the wrong side of the board for the kind of function the board is to do. Remember:
- Setting the destination address of an XBee module to the wrong address.
- Resetting the XBee radio back to the default settings and forgetting to change the baud rate back to the 57,600 that Renard uses.
- If using the Ren-W to transmit control commands to a Ren-C/595 or Ren-C/Grinch controller, be sure that the cat5 cable that goes from J2 of the Ren-W to the Rs-IN jack of the Ren-C has at least one balun affixed to it. You might also coil the cable several times. This will reduce the amount of EMI and/or RFI that the XBee radio produces, which could be mistaken as serial input and cause framing errors. It's possible that the framing error LED on a Ren-C may light even though everything is functioning properly. This is likely due to some of the XBee's EMI getting through anyway and is probably not a critical issue.
