Assembly Instructions The Renard SS8
Board Assembly
- The following sequence of steps is by no means the only way to assemble the Renard SS8. It is simply a suggested order of events to achieve the desired goal.
- NOTE: The part numbers referenced in the following instructions are those taken from the Renard SS8 BOM.
Triac Heat Sink
- A simple heat sink can be fabricated from .5"x.5"x.060" (1/16”) angle aluminum available at your local home improvement store. A template for the hole pattern can be found here. The triac listed in the BOM has an isolated tab, so no isolators are needed.
Parts Listing (BOM)
IMPORTANT BOM INFORMATION:
QTY | REF | NOMENCLATURE |
511-LF50CV | 1 | U1 | 5 VDC Voltage Regulator |
532-577102B00 | 1 | Heatsink for Voltage Regulator | |
782-H11AA1 | 1 | U2 | Optocoupler, Bi-Directional Input |
520-TCH1843-X | 1 | U3 | Crystal Clock Oscillator, 18.432 MHz |
511-ST485BN | 2 | U4, U5 | Differential Bus Transceivers |
571-1-390261-2 | 2 | IC Socket, 8 pin (for U4 & U5) | |
579-PIC16F688-I/P | 1 | U6 | PIC Microcontroller |
571-1-390261-3 | 1 | IC Socket, 14 pin (for U6) | |
859-MOC3023 | 8 | M1-M8 | Optoisolator, Triac Driver |
571-1-390261-1 | 9 | IC Socket, 6 pin (for U2, M1-M8) | |
511-BTA04-700T | 8 | T1-T16 | Triac, 4A 700V |
291-750-RC | 2 | R1, R2 | Resistor, Carbon Film 750 ohms 1/4W 5% |
291-120-RC | 1 | R3 | Resistor, Carbon Film 120 ohms 1/4W 5% |
299-1K-RC | 2 | R4, R7 | Resistor, Carbon Film 1K ohms 1/8W 5% |
299-27K-RC | 3 | R5, R8, R9 | Resistor, Carbon Film 27K ohms 1/8W 5% |
299-680-RC | 9 | R6, R10-R17 | Resistor, Carbon Film 680 ohms 1/8W 5% |
291-180-RC | 8 | R18 – R25 | Resistor, Carbon Film 180 ohms 1/4W 5% |
264-330-RC | 1 | RN1 | Resistor Network, 6 pin, 330ohms 2% |
625-1N5817-E3 | 4 | D1-D4 | Diode |
78-1N5239B | 1 | D6 | Diode, Zener 9.1V .5W |
78-1N5229B | 1 | D5 | Diode, Zener 4.3V .5W |
604-WP7104IT | 2 | FE, OE | LED, 3mm Red |
604-WP7104GT | 4 | PWR, HB, ZC, SD | LED, 3mm Green |
140-XRL16V2200-RC | 1 | C1 | Radial Electrolytic Capacitor 16V 2200uF 20% |
667-ECA-1CM470 | 1 | C2 | Radial Electrolytic Capacitor 16V 47uF 20% |
80-C322C104K5R | 1 | C3 | Capacitor, Radial Ceramic 50V 0.1uF |
571-2828372 | 8 | Channel Terminals | Terminal Block, 2 Pos 5.08 mm |
571-7969492 | 1 | Power Terminal | Terminal Block, 2 Pos 5.08 mm |
152-3409 | 1 | JDP1 | D-Sub Connectors, Right Angle DE9 |
571-5556416-1 | 2 | J1, J2 | Jack, Modular RJ45 PCB Mount Top Entry |
538-22-03-2021 | 3 | JP1-JP3 | Header, 2 Pin |
151-8000 | 3 | Shunt | |
504-GMA-10 | 1 | F1 | Fuse, Fast Acting 10A |
534-3517 | 2 | Holder, Fuse Clip PCB mount 5mm | |
534-3527C | 1 | Cover, Fuse | |
838-3FS-312 | 1 | TF1 | Power Transformers 12.6VCT@.2A 6.3V@.4A Single Primary |
Below is the same parts list as above but it is formatted for direct importing into the Mouser BOM feature. Just copy and paste the list as is.
511-LF50CV|1 532-577102B00|1 782-H11AA1|1 520-TCH1843-X|1 511-ST485BN|2 571-1-390261-2|2 579-PIC16F688-I/P|1 571-1-390261-3|1 859-MOC3023|8 571-1-390261-1|9 511-BTA04-700T|8 291-750-RC|2 291-120-RC|1 299-1K-RC|2 299-27K-RC|3 299-680-RC|9 291-180-RC|8 264-330-RC|1 625-1N5817-E3|4 78-1N5239B|1 78-1N5229B|1 604-WP7104IT|2 604-WP7104GT|4 140-XRL16V2200-RC|1 140-XRL16V47-RC|1 80-C322C104K5R|1 571-2828372|8 571-7969492|1 152-3409|1 571-5556416-1|2 538-22-03-2021|3 151-8000|3 504-GMA-10|1 534-3517|2 534-3527C|1 838-3FS-312|1
