Troubleshooting Guide Renard 64XC
Basic Troubleshooting Info
Verify Setup
Most Common Problems
- Incorrect Vixen Settings. It cannot be emphasized enough, the Renard boards will not work correctly if Vixen is not setup correctly. Verify that you have the Vixen plug-in settings correct as compared to the Renard 64XC Controller wiki. The settings in Vixen mus match the setting used in the Renard Firmware burned onto the PICs.
Troubleshooting Flow
Troubleshooting Steps
 - Turn ON AC power
 - PWR LED should be lit
 - Run a Vixen sequence
- If they do, go to step 15
 - Turn OFF AC power
 - Swap PIC chips U10 and U9
 - Turn ON AC power
 - Turn OFF AC power
 - Swap PIC chips U10 and U8
 - Turn ON AC power
- If they don’t, replace PIC chip U6 and retest
Symptom(s):
- PWR LED not lit
 - IC Chips hot to the touch
Possible Problem(s):
- No Input Voltage Present
 - Transformer Bad
 - Voltage Regulator Bad
 - Diode Polarity Wrong
 - Capacitor Polarity Wrong
 - LED installed backwards
The complete pdf version of this flowchart can be found File:TS Renard 64XC Flowchart.pdf
- Remove power from Renard SS24
 - Disconnect all cables.
 - If installed, remove all 30 IC chips from their sockets (U2, U4 thru U8, and M1 thru M24).
 - Turn ON AC power.
 - Did the fuse blow?
- If it did, go to step 17
- If incorrect, go to step 13
 - Did the PWR LED light?
- If it did, go to step 21
 - Measure AC voltage between  top side of F1 and any N terminal.
 - Measure AC voltage between  bottom side of F1 and any N terminal.
 - Turn OFF AC power
 - Remove F1
 - Turn ON AC power
 - Recheck AC voltage between  bottom side of F1 and any N terminal.
 - Bad/shorted triac
 - Turn OFF AC power
 - Install one of the IC chips (U2, U4 thru U8, and M1 thru M24) into its respective socket.
 - Turn ON AC power
Symptom(s):
 - HB and ZC LED do not flash
 - FE and/or OE LEDs light
- Oscillator bad
 - Zero Cross signal bad
 - Vixen settings incorrect
 - PIC bad
- Turn OFF AC power
 - Remove PIC chip U6
 - Turn ON AC power
 - The  Beta Renard Diagnostic Firmware should perform the following channel test:
- Replace U2
 - Check the values of R1 & R2
REMINDER:
NOTE:
 - SD LED will be ON whenever Vixen sends data to the Renard SS24.  The FE and OE LEDs should remain OFF.
 - Replace U5
- Turn OFF AC power
 - Turn ON AC power
- HB LED should light
- ZC LED should light
- SD LED should light
- FE LED should light
- OE LED should light
 - b. Remove shunt from JP3
 - d. Install shunt on JP3
 - If incorrect, replace RN1
Symptom(s):
- Bad triac
 - Bad opto
 - Bad/missed solder joints
- Turn OFF AC power
 - Are channels 13 thru 24 bad?  If they are,
- Check the right side fuse
- If not, go to step 21
 - Turn ON AC power
 - Test lights should be OFF
- Turn OFF AC power
 - Install PIC chip U6
 - Turn OFF AC power
 - Turn OFF AC power
 - Turn ON AC power
SAFETY NOTICE:
- Bad triac
- It should be 5 VDC
- If not, go to step 37
 - Remove PIC chip U7
 - Turn ON AC power
- Turn OFF AC power
 - Install PIC chip U7
 - Turn OFF AC power
 - Turn OFF AC power
 - Turn ON AC power
SAFETY NOTICE:
- Bad triac
 - Remove PIC chip U8
 - Turn ON AC power
- Turn OFF AC power
 - Install PIC chip U8
 - Turn OFF AC power
 - Turn OFF AC power
 - Turn ON AC power
SAFETY NOTICE:
- Bad triac
 - Turn OFF AC power
 - Turn ON AC power
 - Is the test light still ON?
