Troubleshooting Guide Renard 64XC
Basic Troubleshooting Info
Verify Setup
Most Common Problems
- Incorrect Vixen Settings. It cannot be emphasized enough, the Renard boards will not work correctly if Vixen is not setup correctly. Verify that you have the Vixen plug-in settings correct as compared to the Renard 64XC Controller wiki. The settings in Vixen mus match the setting used in the Renard Firmware burned onto the PICs.
Troubleshooting Flow
Troubleshooting Steps
 - Turn ON AC power
 - PWR LED should be lit
 - Run a Vixen sequence
- If they do, go to step 15
 - Turn OFF AC power
 - Swap PIC chips U10 and U9
 - Turn ON AC power
 - Turn OFF AC power
 - Swap PIC chips U10 and U8
 - Turn ON AC power
 - Turn OFF AC power
 - Swap PIC chips U10 and U7
 - Turn ON AC power
 - Turn OFF AC power
 - Swap PIC chips U10 and U14
 - Turn ON AC power
 - Turn OFF AC power
 - Swap PIC chips U10 and U13
 - Turn ON AC power
 - Turn OFF AC power
 - Swap PIC chips U10 and U12
 - Turn ON AC power
 - Turn OFF AC power
 - Swap PIC chips U10 and U11
 - Turn ON AC power
Symptom(s):
- PWR LED not lit
 - IC Chips hot to the touch
Possible Problem(s):
- No Input Voltage Present
 - Transformer Bad
 - Voltage Regulator Bad
 - Diode Polarity Wrong
 - Capacitor Polarity Wrong
 - LED installed backwards
 - Disconnect all cables.
 - In normal use, the Renard 64XC does not require a fuse.  However, since this section is about "problems", it is prudent to have one installed.  The best way to do this is with an in-line fuse holder on the incoming power.  Mouser PN#576-150274 (holder) and PN#576-0235.300MXP (fuse) are perfect for this.
 - If not installed already, install an appropriate rated fuse in the SSR fuse holder. Use the smallest value fuse that you have available for this portion of testing.
- Using a smaller fuse here is for safety during initial power testing. If there are any problems with bad triacs, bridged solder pads or a bad transformer during first power application, a small fuse will blow before any permanent damage to the SSR PCB can occur. For testing one SSRez channel at a time (for example), the recommended fuse size is 1A. This is a standard 5x20mm fuse available most anywhere.
 - Did the SSR fuse blow?
 - Did the PWR LED light Up?
 - Measure DC voltage on  output side of R19.  This is the end closest to  the Power LED.
 - Measure DC voltage on  input side of R6.  This is the end away from the Power LED
 - (??)Measure AC voltage between  top side of F1 and any N terminal.
 - (??)Measure AC voltage between  bottom side of F1 and any N terminal.
 - (??)Turn OFF AC power
 - (??)Remove F1
 - (??)Turn ON AC power
 - (??)Recheck AC voltage between  bottom side of F1 and any N terminal.
 - Bad/shorted triac
 - Turn OFF AC power
 - Turn ON AC power
 - Did the PWR LED light?
Symptom(s):
 - HB and ZC LED do not flash
 - FE and/or OE LEDs light
- Oscillator bad
 - Zero Cross signal bad
 - R1/R2 are the Wrong Value
 - Vixen settings incorrect
 - PIC bad
- Turn OFF AC power
 - Remove PIC chip U6
 - Turn ON AC power
 - The  Beta Renard Diagnostic Firmware should perform the following channel test:
- Replace U2
 - Check the values of R1 & R2
REMINDER:
NOTE:
 - SD LED will be ON whenever Vixen sends data to the Renard SS24.  The FE and OE LEDs should remain OFF.
 - Replace U5
- Turn OFF AC power
 - Turn ON AC power
- HB LED should light
- ZC LED should light
- SD LED should light
- FE LED should light
- OE LED should light
 - b. Remove shunt from JP3
 - d. Install shunt on JP3
 - If incorrect, replace RN1
Symptom(s):
- Bad triac
 - Triac in Backwards
 - Bad opto
 - Opto/MOC in Backwards
 - Bad/missed Solder Joints
- Turn OFF AC power
 - Are channels 13 thru 24 bad?  If they are,
- Check the right side fuse
- If not, go to step 21
 - Turn ON AC power
 - Test lights should be OFF
- Turn OFF AC power
 - Install PIC chip U6
 - Turn OFF AC power
 - Turn OFF AC power
 - Turn ON AC power
SAFETY NOTICE:
- Bad triac
- It should be 5 VDC
- If not, go to step 37
 - Remove PIC chip U7
 - Turn ON AC power
- Turn OFF AC power
 - Install PIC chip U7
 - Turn OFF AC power
 - Turn OFF AC power
 - Turn ON AC power
SAFETY NOTICE:
- Bad triac
 - Remove PIC chip U8
 - Turn ON AC power
- Turn OFF AC power
 - Install PIC chip U8
 - Turn OFF AC power
 - Turn OFF AC power
 - Turn ON AC power
SAFETY NOTICE:
- Bad triac
 - Turn OFF AC power
 - Turn ON AC power
 - Is the test light still ON?
