Glossary
A
- Amp
- Anode
- AWG
B
- Base
- Baud
- BNC
- BOM
C
- Capacitor
- Cathode
- Center Tap
- Channel
- COOP
- Coop Olsen 595
- COOP SSR
- Coaxial Cable
- Collector
- Continuity
- Current
D
- dB
- Decoupling capacitor
- Dielectric
- Diode
- DIP
- Dipole
- DIYC
 - Do It Yourself Christmas.com
- DMX (or DMX512)
 - Digital Multiplex. A lighting control protocol standard developed to handle communications between commercial (usually entertainment, such as theater or music events) lighting control boards and the individual devices, such as lekos (elliposoidals), fresnels, moving lights, strip lights or DJ effect lights. DMX allows up to 512 devices to be attached, daisy-chain, to one wire, each controlled individually. For more information on DMX click here.
E
- Electrode
- Electrolyte
- Electrolytic Capacitor
- Emitter
- Energized
- ESD
F
- Farad
 - The basic unit of capacitance. A capacitor has a capacitance of 1 farad when a voltage potential of 1 volt across it produces a charge of 1 coulomb. Most capacitors used on DIYC boards are in the microfarad (labeled mF or uF) or picofarad (labeled pF) range.
- FCC
- FET
- Firmware
- Flux
- Full-Wave Rectifier
- Fuse
G
- GFCI
- GRINCH
- Ground
H
- Half-Wave Rectifier
- Heat Shunt
- Heat Sink
 - A piece of metal attached to an electronics component (such as microprocessor, microcontroller, Triac, optoisolator) that serves to dissipate or absorb unwanted heat. Many electronics components have two ratings, a lower one when a heat sink is not used and a higher one where a heat sink is in place. Also called a dissipator.
I
- Inductance
- Induction
- Insulated
- Insulation
- Insulation Resistance
- Insulator
- Integrated Circuit (IC)
- Inverter
J
- Jumper
K
L
- LED
M
- Microcontroller
- MOC3023
- MOSFET
- MOV
- Multimeter
N
- NPN
O
- Ohm
- Ohm's Law
- Olsen 595
- Open or Open Circuit
- Oscillator
P
- Parallel Port
- PCB
- PIC
- Polarity
- Potentiometer
- Power
- Programmer
- Protocol
Q
R
- Regulator
- Relay
- Renard
- Resistance
- Resistor
- RJ-45 (or RJ45)
- RoHS
- RS232
- RS485
S
- Schematic
- Short Circuit
- Shunt
- Silk Screen
- Sink Current
- SMT (or SMD)
- SNR
- Source Current
- SPT(1-3)
- SSR
 - DIYC definition
- SSROZ
- SWR
T
- Tinning
- Transformer
- Transistor
- Triac
- Twisted Pair
U
- ULN2803
- USB
V
- Via
 - A plated-thru hole in a printed wiring board. A via may may exist between one or more adjacent board layers, or through the entire board. A blind via runs vertically between the top [or bottom] side and through one or more adjacent board layers, but not through the entire board.
- Voltage
- Voltage Drop
- Voltage regulator
 - An electronic device designed to take a higher voltage and make it conform to a specific lower voltage. Provide a 5-volt regulator with 12 volts as an input and it will put out a steady 5 volts; provide a 12-volt regulator with 13 volts and it will output a steady 12 volts. While some regulators are designed for specific voltages, others can provide a range of voltages depending upon resistance applied; variable voltage regulators can be controlled by potentiometers (i.e.: volume control), so that you can turn a knob and get various voltages depending on where the knob is.
W
- Watt
X
- XLR Connector
- XTAL
 - Short for crystal.
Y
Z
- Zener Diode
 - Zero Crossing
