Renard Data Cables
The data cables shown on this page apply to the current Renard board designs at DIYC. Some earlier designs/prototypes may have different cable requirements, when in doubt check the dedicated wiki page for that particular board.
Directly to computer COMM port (RS232 connection)
Mainly for Renard 64XC and Renard SS boards PC DE9 Pin 3 to Renard DE9 Pin 3 PC DE9 Pin 5 to Renard DE9 Pin 5
Using a RS232->RS485 or USB->RS485 converter
In a DMX environment
Connecting multiple Renard boards
Generally only a regular straight-thru CAT5 cable is required to connect a Renard board to other Renard boards. For the few exceptions (ie Ren24 V2.5), check the wiki page for those boards to see what their unique requirements are.
