Simple Renard RGB+W
Simple Renard RGB+W Parts
Part | Description | Mouser PN | Qty |
P1 | Tyco Terminal Block 2P Vertical | 571-7969492 | 2 |
C1,C2 | 47uf 35V Electrolytic | 647-UVZ1V470MDD | 2 |
C6 | .33uf | 81-RDER71H334K1K103B | 1 |
C3,C4,C5 | .1uf | 81-RPEF51104Z2S2A03A | 3 |
D1 | 1N5229(4.3v) | 78-1N5229B | 1 |
D2 | 1N5239 (9.1v) | 78-1N5239B | 1 |
IC1 | 65LBC179 | 595-SN65LBC179P | 1 |
IC3 | LM7805CT | 512-LM7805CT | 1 |
40 Pin IC Socket | 517-4840-6000-CP | 1 | |
IC5 | PIC18F4520 or 4620 and 4525 | 579-PIC18F4520-I/P | 1 |
ICSP | 6 pin header | 571-6404526 | 1 |
JP2 XBee header | 5 pin header | 571-640452-5 | 1 |
Shunt for XBheader and Vreg bypass | Shunt | 737-MSC-G | 3 |
JP3 Vreg bypass | 2 pin header | 571-6404522 | 1 |
J1-J10 | RJ45 Jack | 571-5555164-1 | 10 |
Status Led | yellow 3MM LED | 604-WP132XYD | 1 |
Power Led | Green 3MM LED | 604-WP132XID | 1 |
RX/TX Led | Green 3MM LED | 604-WP132XGD | 1 |
R1,R2,R6 | 1k ohm resistor 1/8 watt | 299-1k-RC | 3 |
R3,R7 | 330 ohm resistor 1/8 watt | 299-330-RC | 2 |
R4 | 10k ohm resistor 1/8 watt | 299-10k-RC | 1 |
R5 | 120 ohm resistor 1/8 watt | 299-120-RC | 1 |
R9,R10 | 27k ohm resistor 1/8 watt | 299-27k-RC | 2 |
R11-42 | 820 ohm resistor 1/8 watt | 299-820-RC | 32 |
T1-32 | Transistor PN2222AG | 863-PN2222AG | 32 |
PIC Bypass | Header | 571-3-644456-3 | 1 |
8 pin IC socket | 517-4808-3004-Cp | 1 |
Housing
Building the Simple Renard RGB+w
- Install the resistors:
- Install the capacitors:
- Install the IC socket:
- Install the transistors:
- Install the 5v linear regulator
Final Testing
Mounting in Housing
Connecting up the Simple Renard RGB+w
Pin 1 - Pin 2 - Pin 3 - Pin 4 - Pin 5 - Pin 6 - Pin 7 - Pin 8 -
PCB
Design Options
