Solid State Relays
A Solid State Relay, or SSR, is an electronic device that uses low voltage input to switch high voltage on or off. It is used in Christmas displays to allow the controller to switch the lights on and off. This article will show one who is not familiar with the device a basic overview of how it works.
There are two types of SSRs, AC SSRs (the most common) and DC SSRs. As most Xmas lights are AC powered (110VAC or 24 VAC), DIYC members will use a AC Power SSR to switch or dimm the lights.
For specific requirements (Low Voltage LED MR16 spots and halloween devices) a DC SSR is recommended.
Circuit Diagram
A generic SSR circuit diagram is available for download. The SSR depicted in the above schematic is good for controlling resistive loads (lights, resistors). The SSR design for controlling inductive loads (motors, solenoids, etc) is more complicated, and can be found at other sites on the Internet.
Components
There are a few basic components that make up a Solid State Relay.
Triac
Optocoupler
Fuse
Resistors
Wiki Links
4 Channel SSR Parts List Sean Bowf Coop Board
4 Channel SSROZ Assembly Instructions
Designs with detailed information
- John Wilson's DC SSR 4 Channel
- Andrew Williams DCSSR Version 2.4 4-Channel
- Chris and John's SSRez 4 Channel
- Sean Bowf Standard 4-Channel
- Dave & Greg's SSRneon-G2-LED 4-Channel
- Dave's SSRneon-G2 4-Channel
- Robert Stark 4-Channel
- Robert Stark 6-Channel Power Strip
- Robert Stark 12-Channel
- Frank Kostyun 4-Channel
- David Fansler 8-Channel
- Orien Love 4-Channel Enclosure
- Rodney Harris Pod Enclosure
