FM02 Gallery
Pictures of Various FM02 and other VAST product Installations
By OregonLights.
FM02
By OregonLights.
FM02
By Underdog.
FM02
By Underdog.
FM02
By CaptKirk.
FM02
Mounted in an Aluminum case -
By chelmuth.
FM02
By chelmuth.
FM02
By smartalec.
FM02
By RobDude30.
FM02
By RobDude30.
FM02
By rkhanso.
FM02
I have one of the Vastelec FM-02 transmitters and wanted to permanently mount it in a metal electrical box for shielding. It's not so easy to mount the transmitter board flush with the box and have the holes line up for the power, antenna and audio and make it still look OK. -
By rkhanso.
FM02
By klanger.
By AURBO99.
My FM02 was installed in an old CD-ROM case. It includes the miniRDS unit.
By AURBO99.
My FM01 installation in a Hammond project box. It includes the miniRDS unit.
By imbluenote.
By kingofkya.
By dmcole.
1 Watt VAST unit
By rogelio.
FM02 with MicroRDS unit
By rfallatt
FM02
By rfallatt
FM02
By rfallatt
FM02
By SamJ435.
By SamJ435.
By pcoshatt
FM02
By pcoshatt
FM02
Continuation of the image to the left. This shows the mounting of the main FM02 board with the display board removed.
