Pixel Properties
Form Factor
- 12mm pixel nodes
- Strips (Usually 5M length)
- Bare board (no waterproofing)
- Hollow Tube
- Solid Tube
- Solid Silicone
- Solid Epoxy Resin
- Modules
- Square
- Rectangular
LEDs per meter
- 30 LED/m
- 60 LED/m
- Strings
Power Supply Voltage
LED Type
- 3528 surface mount (3.5mm x 2.8mm) (typically used in strips and modules)
- 5050 surface mount (5.0mm x 5.0mm) (typically used in strips and modules)
- 8mm (typically used in strings)
Waterproofing
- Injection Molded Silicone
- Epoxy Resin coated PCB in Silicone
- Cast Epoxy Resin in Sleeve
- Cast Epoxy Resin coated PCB
- SM16715
- SM16716
- P9813 - 4 wire
- P9816 - 4 wire
- MY9941 (Native DMX)
- MY9942 (Native DMX)
- MY9943 (Native DMX)
| Form Factor |
IC |
Length |
Voltage |
LEDs per Meter |
ICs per meter |
Link
| Example |
Example |
Example |
Example |
Example |
Example |
Example
DIYLEDEXPRESS.COM
Ray Wu
| Form Factor |
IC |
Length |
Voltage |
LEDs per Meter |
ICs per meter
| Example |
Example |
Example |
Example |
Example |
Example
| Form Factor |
IC |
Length |
Voltage |
LEDs per Meter |
ICs per meter
| Example |
Example |
Example |
Example |
Example |
Example
| Form Factor |
IC |
Length |
Voltage |
LEDs per Meter |
ICs per meter
| Example |
Example |
Example |
Example |
Example |
Example
| Form Factor |
IC |
Length |
Voltage |
LEDs per Meter |
ICs per meter
| Example |
Example |
Example |
Example |
Example |
Example
| Form Factor |
IC |
Length |
Voltage |
LEDs per Meter |
ICs per meter
| Example |
Example |
Example |
Example |
Example |
Example
| Form Factor |
IC |
Length |
Voltage |
LEDs per Meter |
ICs per meter
| Example |
Example |
Example |
Example |
Example |
Example
| Form Factor |
IC |
Length |
Voltage |
LEDs per Meter |
ICs per meter
| Example |
Example |
Example |
Example |
Example |
Example
| Form Factor |
IC |
Length |
Voltage |
LEDs per Meter |
ICs per meter
| Example |
Example |
Example |
Example |
Example |
Example
