Different Styles of Pixels
Pixel Properties
Form Factor
 - Strips (Usually 5M length)
 - Modules
LEDs per meter
- Strips
- 30 LED/m
 - 60 LED/m
- Strings
Power Supply Voltage
- 5VDC
 - 12VDC
 - 24VDC
LED Type
Waterproofing
Wire Size
 - 20 Guage wire
 - LPD1101
 - UCS6909
 - UCS6912
- LPD8806
 - LPD8809
 - SM16715
 - SM16716
 - P9813 - 4 wire
 - P9816 - 4 wire
 - TLS3002
 - CYT3001
 - CYT3005 - 3 wire
- MY9941 (Native DMX)
 - MY9942 (Native DMX)
 - MY9943 (Native DMX)
DIYLEDEXPRESS
| Form Factor | IC | Length | Voltage | LEDs per Meter | ICs per meter | Link | Image | Note |
| String | WS2801 | 50 pixels (6m) | 5vdc | 10 | 10 | link | IP68 | |
| String | WS2811 | 50 pixels (6m) | 5vdc | 10 | 10 | link | IP68 | |
| String (Square) | WS2811 | 50 pixels (6m) | 12vdc | 10 | 10 | link | IP68 | |
| Module (Rectangular) | WS2811 | 20 pixels (2m) | 12vdc | 10 | 10 | link | ||
| Strip | WS2811 | 50 pixels (5m) | 5vdc | 30 | 10 | link | Silicone Tube | |
| Strip | WS2811 | 100 pixels (5m) | 5vdc | 60 | 20 | link | Silicone Tube | |
| Strip | TM1809 | 150 Pixels (5m) | 12vdc | 30 | 10 | link | Silicone Tube |
Ray Wu
| String | WS2811 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68 | |
| String (square) | WS2811 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68 | |
| String (square) | WS2811 | 100 pixels (10m) | 12vdc | 10 | 10 | link | IP66 | |
| Strip | WS2811 | 50 pixels (5m) | 5vdc | 30 | 30 | link | Silicone tube | |
| Example | Example | Example | Example | Example | Example | Example | Example | |
Stellascapes
| String (Stella-green) | WS2801 | 85 pixels | 5vdc | 10 | 10 | link | |
| String (Stella-black) | WS2801 | 42 or 85 pixels | 5vdc | 10 | 10 | link |
