Different Styles of Pixels
Pixel Properties
Form Factor
- Strips (Usually 5M length)
- Modules
LEDs per meter
- Strips
- 30 LED/m
- 60 LED/m
- Strings
Power Supply Voltage
- 5VDC
- 12VDC
- 24VDC
LED Type
Waterproofing
Wire Size
- 20 Guage wire
- LPD1101
- UCS6909
- UCS6912
- LPD8806
- LPD8809
- SM16715
- SM16716
- P9813 - 4 wire
- P9816 - 4 wire
- TLS3002
- CYT3001
- CYT3005 - 3 wire
- MY9941 (Native DMX)
- MY9942 (Native DMX)
- MY9943 (Native DMX)
DIYLEDEXPRESS (USA Based run by DIYC user tjetzer)
| Form Factor | IC | Length | Voltage | LEDs per Meter | ICs per meter | Link | Image | Note |
| String | WS2801 | 50 pixels (6m) | 5vdc | 10 | 10 | link | IP68 | |
| String | WS2811 | 50 pixels (6m) | 5vdc | 10 | 10 | link | IP68 | |
| String (Square) | WS2811 | 50 pixels (6m) | 12vdc | 10 | 10 | link | IP68 | |
| Module (Rectangular) | WS2811 | 20 pixels (2m) | 12vdc | 10 | 10 | link | ||
| Strip | WS2811 | 50 pixels (5m) | 5vdc | 30 | 10 | link | silicone tube | |
| Strip | WS2811 | 100 pixels (5m) | 5vdc | 60 | 20 | link | silicone tube | |
| Strip | TM1809 | 150 Pixels (5m) | 12vdc | 30 | 10 | link | silicone tube |
Ray Wu (China Based)
| String | WS2801 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68 | |
| String | WS2801 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68, with faceted C9 cover | |
| String | WS2801 | 100 pixels (10m) | 12vdc | 10 | 10 | link | IP68 | |
| String (square) | WS2801 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68 | |
| String (square) | WS2801 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP66, side wire | |
| String (square) | WS2801 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68, with faceted C9 cover | |
| Strip | WS2801 | 160 pixels (5m) | 5vdc | 32 | 32 | link | IP65, silicone tube | |
| Strip | WS2801 | 60 pixels (5m) | 12vdc | 36 | 12 | link | IP65, silicone tube | |
| Module (square) | WS2801 | 20 pixels | 12vdc | 40 | 10 | link | ||
| String | WS2811 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68 | |
| String | WS2811 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP66, with 4 pin waterproof connectors | |
| String (square) | WS2811 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68 | |
| String (square) | WS2811 | 100 pixels (10m) | 12vdc | 10 | 10 | link | IP66, side wire | |
| Strip | WS2811 | 150 pixels (5m) | 5vdc | 30 | 30 | link | silicone tube | |
| Strip | WS2811 | 240 pixels (4m) | 5vdc | 60 | 60 | link | silicone tube | |
| Module (rectangular) | WS2811 | 20 pixels | 12vdc | 30 | 10 | link | ||
| String | LPD6803 | 50 Pixels (5m) | 5vdc | 10 | 10 | link | IP68 | |
| String (square) | LPD6803 | 50 Pixels (5m) | 5vdc | 10 | 10 | link | IP68 | |
| Strip | LPD6803 | 50 Pixels (5m) | 12vdc | 30 | 10 | link | IP68, similar to LOR CCR | |
| Module (square) | LPD6803 | 20 pixels (2m) | 12vdc | 10 | 10 | link | 3 LEDs | |
| Module (rectangular) | LPD6803 | 20 pixels (2m) | 12vdc | 10 | 10 | link | 3 LEDs | |
| String | TLS3001 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68 | |
| String | TLS3001 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68, with 4 pin waterproof connectors | |
| String (square) | TLS3001 | 50 pixels (5m) | 5vdc | 10 | 10 | link | IP68 | |
| Strip | TM1809 | 150 pixels (5m) | 12vdc | 30 | 10 | link | IP67, silicone tube | |
| Strip | TM1809 | 150 pixels (5m) | 12vdc | 30 | 10 | link | IP65, silicone coating | |
| Strip | TM1809 | 240 pixels (5m) | 12vdc | 48 | 16 | link | IP68, silicone tube |
Retail Store (i.e. Lowes)
| String | GECE | 25,36,50 pixels (20,29,41ft) | 5vdc | 4 | 4 | link | G35 Cover, General Electric Color Effects |
Stellascapes (New Zealand Based)
| String (Stella-green) | SS-1 | 85 pixels | 5vdc | 10 | 10 | link | bullet or flat packages | |
| String (Stella-black) | SS-1 | 85 pixels | 5vdc | 10 | 10 | link | bullet or flat packages | |
| String | None | 50 nodes (5m) | 5vdc | 10 | 0 | link | IP68 | |
| String | None | 50 nodes (5m) | 12vdc | 10 | 0 | link | IP68 | |
| Strip | None | 5m | 12vdc | 30 | 0 | link | IP65, can be cut every 3 LEDs | |
| Strip | None | 5m | 12vdc | 60 | 0 | link | IP65, can be cut every 3 LEDs | |
| Module (rectangular) | None | 20 nodes | 12vdc | 30 | 0 | link | IP66 |
HolidayCoro (USA Based run by DIYC user dmoore)
| String | None | 50 nodes (5m) | 12vdc | 10 | 0 | link | ||
| Strip | None | 5m | 12vdc | 30 | 0 | link | silicone tube and coating | |
| Module (rectangular) | None | 20 nodes | 12vdc | 10 | 0 | link | 3 LEDs | |
| Module (square) | None | 20 nodes | 12vdc | 10 | 0 | link | 3 LEDs |
| String | None | 100 nodes (10m) | 12vdc | 10 | 0 | link | IP68 | |
| Strip | None | 5m | 12vdc | 30 | 0 | link | silicone tube | |
| Strip | None | 5m | 12vdc | 30 | 0 | link | IP68,silicone coating | |
| Strip | None | 5m | 12vdc | 30 | 0 | link | IP68,silicone tube and coating | |
| Strip | None | 5m | 12vdc | 30 | 0 | link | epoxy coating | |
| Strip | None | 5m | 12vdc | 60 | 0 | link | silicone tube | |
| Strip | None | 5m | 12vdc | 60 | 0 | link | IP68,silicone tube and coating | |
| Strip | None | 5m | 12vdc | 60 | 0 | link | epoxy coating | |
| Module (rectangular) | None | 20 nodes | 12vdc | 10 | 0 | link | IP65, 2 LEDs | |
| Module (rectangular) | None | 20 nodes | 12vdc | 10 | 0 | link | IP66, 3 LEDs | |
| Module (square) | None | 20 nodes | 12vdc | 10 | 0 | link | IP68, 3 LEDs | |
| Module (square) | None | 20 nodes | 12vdc | 10 | 0 | link | IP67, 4 LEDs |
