Creating Basic Effects
Under Development.
Based on Version 11V.
The Window and it's components
The Toolbar and relevant buttons
The Edit Mode in HLS
Applying effects to channels in HLS works differently than some other sequencing programs. When you click the left mouse button in the channel grid, the Edit Mode becomes active and will remain active until you click again or press the ESC key.
- TIP: If you ever want to cancel the selection you are currently working on you may use the ESC key to cancel the previous selection you are working with. For example, if you ever think the software has hung up while you are adding an effect, it really has not. It is probably waiting for you to apply an effect to selected cells. But you can use the ESC key to cancel the last selection. This is also very useful if you select the wrong cells by mistake and want to redo it. Use the ESC key.
Basic Effects
Level
Ramp Up
Ramp Down
Modifying Effects
Moving/Stretching Effects
Deleting Effects
Copy/Paste Effects
Modify Effect Attributes
