Adding and Using Beat Tracks
This is based on version 11V.
HLS supports creating beat tracks in a couple of ways. One way is to manually press a button or click a mouse while a song is playing to set the beat. Another way would be to apply a filter to the audio and then manually "turn on" the beat track at points identified through the filter.
Add Beat Track Channels
![](/wiki/images/thumb/8/8b/HLS_BeatTrack_AddChannels_11V.png/300px-HLS_BeatTrack_AddChannels_11V.png)
First, channels must be added so you can use them as beat tracks.
Setting Display Group for Beat Track
![](/wiki/images/thumb/2/2d/HLS_BeatTrack_AddDisplayGroup_11V.png/300px-HLS_BeatTrack_AddDisplayGroup_11V.png)
- Create a Display Group named "Beat" and add all three channels (See Figure 5-6).
Beat Track From Clicks
Creating a Beat Track from Clicks is one of the easiest ways to create a Beat Track. Clicks must be quick and not everything will line up perfectly, but it can give reasonably good results.
![](/wiki/images/4/4e/HLS_BeatTrack_SelectBeatTrackChannel_11V.png)
- Activate the Beat Track by clicking Manage Channels -> Select a Beat Track Channel.
- Select the Beat Track you want to use and click OK (See Figure 5-7).
![](/wiki/images/thumb/9/96/HLS_BeatTrack_BeatTrackActive_11V.png/300px-HLS_BeatTrack_BeatTrackActive_11V.png)
- Check the box Beat Track Active to let HLS know that you are planning to record clicks for a beat track (see Figure 5-8).
- Press the CTRL key or the Left Mouse' button at each beat in the song.
![](/wiki/images/thumb/8/81/HLS_BeatTrack_ClickTrack_11V.png/300px-HLS_BeatTrack_ClickTrack_11V.png)
- When the song is complete, there will be two grid cells filled in at every click received. Your beat track has been created. (See Figure 5-9)
Beat Track from Filters
Section needs to be completed.
How to use the filters/link to audio file page.
Filling in squares for beat track.
Cleaning up a Beat Track
- When the timing mark is placed where you want it, click on it again (or press escape) to exit selection mode.
