Copying Channel Effects
The following was created with version 11V.
To copy one or more channels left click on the channel name and asterisks will appear to the left of it (see Figure 1-20). Now left click again on the channel name to finish selecting it. Next, select the Manage Channels in the tool bar and choose Copy - Paste Whole Channels. A small window will open and prompt you to Click on the Channel to Paste To. Left click on the channel you want to copy the effect into.
To copy the effects form multiple channels left click on the first channel name to be copied, asterisks will appear to the left of it. Then (without clicking) move your mouse down to include all of the channels you would like to copy (see Figure 1-21). As you move past over the channel names, asterisks will appear to the left of each. Once you have selected all of the channels you want copied (designated by astericks to the left of the channel names) position your mouse cursor over the last channel name to be copied and left click once more to lock the selection in.
Now select the Manage Channels in the tool bar and choose Copy - Paste Whole Channels. Again you will then be prompted to Click on the Channel to Paste To. Note that if you are copying a number of channels you will have to have that many to paste to. In the example shown in Figure 1-21.1 I have copied the first two channels and pasted into the last two channels.
Deleting an Entire Channel’s Effects
To delete all the effects for a channel choose the Manage Channels tab and then select Remove All Effects from a Channel
