Different Styles of Pixels
Pixel Properties
Form Factor
 - Strips (Usually 5M length)
 - Modules
LEDs per meter
- Strips
- 30 LED/m
 - 60 LED/m
- Strings
Power Supply Voltage
- 5VDC
 - 12VDC
 - 24VDC
LED Type
Waterproofing
Wire Size
 - 20 Guage wire
 - LPD1101
 - UCS6909
 - UCS6912
 - LPD8809
 - SM16715
 - P9813 - 4 wire
 - P9816 - 4 wire
 - TLS3002
 - CYT3001
 - CYT3005 - 3 wire
 - MY9942 (Native DMX)
 - MY9943 (Native DMX)
DIYLEDEXPRESS
| String (C9) | WS2811 | 50 pixels (*m) | 12vdc | 3-10 | 3-10 | link | $45.00 | $0.90 | IP68, C9 lens with 2x5050LEDs, available with 4",6",8",10",12" spacing | |
Light-O-Rama (LOR)
(USA Based)
Ray Wu
(China Based)
Retail Store (i.e. Lowes)
Seasonal Entertainment
Stellascapes
DIYLEDEXPRESS
HolidayCoro
| String | None | 50 nodes (5m) | 12vdc | 10 | 0 | link | $32.50 | $0.65 | ||
| Strip | None | 5m | 12vdc | 30 | 0 | link | $49.99 | $10.00/m | silicone tube and coating | |
| Module (rectangular) | None | 20 nodes | 12vdc | 10 | 0 | link | $25.80 | $1.29 | 3 LEDs | |
| Module (square) | None | 20 nodes | 12vdc | 10 | 0 | link | $27.80 | $1.39 | 3 LEDs |
Ray Wu
(China Based)
