Talk:HLS User Manual and Reference Guide
2-1-13 Removed the Audio File page because the information really belonged in various places: Playback for speed control, Beat Track for filtering, etc. It now redirects to the beat track page.
HLS User Manual and Reference Guide - PDF
Getting HLS
Template:Download and Installation (12C)
Template:Upgrading HLS (12C)
Creating a Sequence
Template:HLS Sequence Creation Wizard (12C)
Template:Starting a new HLS Sequence (12C)
Template:Time Resolution (12C)
Channel Management
Template:Setting up HLS Channels (11V)
Template:Advanced Channel Management (11V)
{{RGB Channels]] (12C)
Template:Configuring Display Groups (12C)
Template:Sticky Channels (12C)
Template:Segment Channels
Display Preview
Template:Creating a Display Preview (12C)
Template:Creating Basic Effects (12C)
Template:Adding and Using Beat Tracks (12C)
Template:Setting Defaults for Effects (12C)
Template:Creating Chase Effects (12C)
Template:Mirroring Effects (12C)
Template:Fill Effects (12C)
Template:Over Control Effects (R)
Template:Sequencing with RGB Channels
Template:Custom Effects (R)
Template:Creating a Library of Group Effects (R)
Template:Creating a PixelPlane
Template:The PixelPlane Editor
Template:MegaTree=
Template:Using Nutcracker with PixelPlane
Template:Fill Channels
Template:Transitions Using Overlay Effects
Template:Drawing a PixelPlane in the Display Preview
Sequence Playback
Template:Sequence Playback (12C)
Sequence Output
Template:Hardware Configuration (R)
Template:Selecting the Output Method
Template:Working with Playlists
Template:Creating and Running a Schedule
Template:Trigger Events
Template:RDS Output
Template:Servo Motors
Template:Importing and Exporting with Excel
Template:Importing a Sequence from Vixen (R)
Template:Importing a Sequence from LOR (12C)
Template:Moving or Sharing Sequences
Template:Sharing Library Effects
Template:Copying and Pasting Channels from Another Sequence
