HLS Sequence Creation Wizard
Current as of Version 12C.
HLS now has a built in New Sequence Wizard which will walk you through the steps of creating a sequence. If you are more familiar with the traditional way of creating a sequence, that is still possible.
Setting up the Sequence File:
Setting up the Audio File:
Chapter 1: Getting HLS | Chapter 2: Creating a Sequence | Time Resolution OR Manual Sequence Creation |
