The PixelPlane Editor: MegaTree
Still to document: Text hiding for channels Horizontal Text Vertical Text
Current as of Version 12H.
Spiral
A Spiral effect creates the look of a spiral of lights twisting around the tree.
The Options to customize the Spiral Effect:
- Speed of Rotation: How fast should the spirals rotate (lower numbers mean faster).
- Number of Bars: The number of bars to spiral. Each additional bar will add a new color (max 6). Additional bars after that will repeat the color additions.
- Width of Bars: How wide the bars should be.
- Spiral Spacing: How much space should there be between each spiral.
Vertical Bars
A Vertical Bar effect creates vertical bars that rotate around the tree.
- Speed of Rotation: How fast should the bars rotate (lower numbers mean faster).
- Number of Bars: The number of bars to rotate vertically. Each additional bar will add a new color (max 6). Additional bars after that will repeat the color additions.
Horizontal Bars
A Horizontal Bar effect creates horizontal bars that rotate up or down the tree.
Snow
A Snow effect creates random "snowing" pixels that float down the tree.
Meteor
A Meteor effect creates random meteors that streak down the tree.
Fireworks
A Firework effect creates fireworks that streak down the tree.
- Speed of Rotation: How fast should fireworks come (lower numbers mean faster).
Text Considerations
To be developed. See video 2, @ 1:30 mark.
Horizontal Text
A Horizontal Text effect displays horizontal text that moves across the tree.
Options to Customize a Horizontal Text Effect:
Vertical Text
A Vertical Text effect displays Vertical text that moves up/down the tree.
Options to Customize a Vertical Text Effect:
| The PixelPlane Editor | Chapter 6: The PixelPlane | Using Nutcracker with a PixelPlane |
