The PixelPlane Editor: MegaTree
Still to document: Text hiding for channels Horizontal Text Vertical Text
Current as of Version 12H.
Spiral
A Spiral effect creates the look of a spiral of lights twisting around the tree.
The Options to customize the Spiral Effect:
- Speed of Rotation: How fast should the spirals rotate (lower numbers mean faster).
- Number of Bars: The number of bars to spiral. Each additional bar will add a new color (max 6). Additional bars after that will repeat the color additions.
- Width of Bars: How wide the bars should be.
- Spiral Spacing: How much space should there be between each spiral.
Vertical Bars
A Vertical Bar effect creates vertical bars that rotate around the tree.
- Speed of Rotation: How fast should the bars rotate (lower numbers mean faster).
- Number of Bars: The number of bars to rotate vertically. Each additional bar will add a new color (max 6). Additional bars after that will repeat the color additions.
Horizontal Bars
A Horizontal Bar effect creates horizontal bars that rotate up or down the tree.
Snow
A Snow effect creates random "snowing" pixels that float down the tree.
Meteor
A Meteor effect creates random meteors that streak down the tree.
Fireworks
A Firework effect creates fireworks that streak down the tree. These are exactly the same as meteors, except when sparkle is applied. When it is applied, it will randomly "explode" the firework.
- Speed of Rotation: How fast should fireworks come (lower numbers mean faster).
Text Considerations
To be developed. See video 2, @ 1:30 mark.
Horizontal/Vertical Text
A Horizontal or Vertical text effect displays text that moves across the tree either horizontally or vertically.
- Speed of rotation: How fast the text will rotate on the tree.
- Snow Density: This controls the amount of snow to appear with your text.
- Add background color 6 to text: This will add the 6th color as background behind the text. The intensity field controls how bright that color is.
- Note: You must click the Generate Text button before it will display in the animation window.
Hide Text Strings:
- This allows you to turn off the strings on the backside of the tree for text generation.
- Click the button and then check which channels are on the back of the tree.
Vertical Text
A Vertical Text effect displays Vertical text that moves up/down the tree.
Options to Customize a Vertical Text Effect:
The PixelPlane Editor | Chapter 6: The PixelPlane | Using Nutcracker with a PixelPlane |
