Upgrading HLS
Current as of version 12E
Standard Upgrade
- Simply download the latest version, unzip the files, and overwrite the old files with the new ones.
Upgrade Path for Skipped Updates
- Upgrading from a version less than 11E: Install version 11H [1]
 - Next, upgrade from 11H to the most current version. [2]
| Download and Installation | Chapter 1: Getting HLS | Chapter 2: Creating a Sequence |
