Hardware Configuration
In Revision. Feel free to help!
To output your sequence data to your light controllers, there are specific components that must be defined in HLS output settings:
- Physical Hardware Settings
- Universe Assignment
- Output Protocol
Setting Up Com Ports
Setting up a Network
Universe Assignment
Once the physical hardware connections have been defined, HLS needs to know where to send each universe of channel data.
- Each of your created universes will appear. (See Figure)
Transport
Protocol
- Choose protocol.
- Details on protocols
- Status equals 1 is good.
Active
Output Sequence
Hardware Tests
Testing hardware.
