Channel Management:
Channel Management
Setting up HLS Channels (13F)
HLS Channels are controlled using the Manage Channels Menu at the top of the screen. See figure 3-1. While there are many functions on this menu, this document will mainly focus on the first option: Manage Raw Channels. Select this option to add and manipulate the raw channels associated with the sequence you are working with.
Important: If you plan to use a time resolution that is different than the default (50 msec), it MUST be set BEFORE you add any channels. Once you add channels, this time resolution CANNOT be changed.
Next we will set up HLS Channels.  Click on the Manage Channels tab at the top of the page and then click on Manage Raw Channels. At this point you will see a message reminding you to choose your time period resolution before you continue (see Figure 3-2). Next, click on the OK button.
Adding Basic HLS Channels
The Channel Manager screen will now as appear (see Figure 3-3). This is where we will add and configure HLS channels.
- HLS Channels are not the same as channels on a controller. HLS channels can represent a strand of incandescents or LED's, a "super string" of 3 light colors connected to the same object, a dumb RGB item, a single pixel, or a plane of pixels. This versatility is one of the features that sets HLS apart from some other sequencers.
 - Output channel configuration is handled in the "Output" section of HLS and cannot be setup from the Raw Channel Manager.
To add channels:
- In the # of Channels to Add field, type the numeric value of number of channels to add.
 - Click the Add button to create the channels.
Naming Channels
HLS will pop up a window asking for the common name for the channels (See Figure 3-4).  You can enter anything in the blank and HLS will auto-number the channels, starting at 1.  If you would rather NOT start at 1, you can input a different number in parenthesis. For example, to add channels starting with number 15, you could enter Chan(15) into the box.  Hit Enter when complete.
Changing the Assigned Universe
When adding channels, HLS automatically assigns them to Universe 0. Any channels assigned to Universe 0 will NOT output to controllers. If you'd like to, you can go ahead and assign channels to a universe. Or, if you prefer, you can do this when you are ready to set your channels up for output.
- In the example of Figure 3-5, 10 HLS channels have been added.
 - To change them to Universe 1:
- Select all channels to change by clicking on the top channel (inside any box) and drag the mouse cursor down until all channels are selected.
 - Enter the number one into the Renumber Selected Universe field.
 - Click the Renumber Universe button.
 - Note: Some channels will always be Universe 0. Channels like beat tracks, pixel planes, lighting channels, and segments are not designed for output. These types of channels will be discussed further in the guide.
Applying Colors to Channels
Setting a color for an HLS channel is important as it is the color that appears in the sequencer as you add effects and is also used in the Display Preview.
- In the top right corner, there is a color block. Click it to bring up the Color Picker (See figure 3-7).
 - Once the Color Picker is open, you can easily set it to one of the more common lighting colors or you can click the drop down box in the bottom left to choose any color you like.
 - Once you have selected a color, click OK to use it.
 - Right-click in the Color column of any channels you want to be demonstrated with that color. (See figure 3-8.)
 - Hint: To save time, choose one color at a time and set all same-colored channels at the same time before switching to another color.
Simple Renaming
Generally, you won't want to keep a bunch of channels with the same name. Or you may want to make minor changes to names as you go along. In the example shown in Figure 3-9, the first channel has been renamed and the second channel is in process of being renamed.
- First, you MUST check the UnFreeze Name to Edit box in the top left.
 - Once names are unlocked, click into the field and type a new name.
 - Group renaming, using folders, moving items, and other complex tasks are in the Advanced Channel Management section.
Advanced Channel Management (13F)
 - Order: This field is used to adjust the DISPLAY order of the channels.
Advanced Renaming Channels
When adding a bulk group of channels, HLS will ask for a base name to start with, but you most likely will want to customize the names for your purpose.  You can rename individual channels, rename using the bulk renaming utility, and even create names in excel that you paste into the Channel Manager.
Rename Individual Channels:
Bulk Channel Renaming:
Method One:
 - Examples:
Method Two:
Reordering Channels
To ReOrder channels:
 - Click ReOrder Channels.
Using Folders
Create a New Folder:
Remove channels from a folder:
Opening and Closing Folders:
VIDEO: Joe describes folders and folder management
Copying Channels
To copy multiple channels click on the first channel to be copied and asterisks will appear to the left of the channel name. The without clicking move your mouse down to include all of the channels you would like to copy (see Figure 3-20). Asterisks will appear to the left of the channel to be copied. Once you have selected all of the channels to be copied click again on the last channel to be copied to select all of them.
Deleting Channels
| Figure 3-21: Click the Delete Selected Channels button. |
| Figure 3-22: Confirm you wish to delete by clicking yes. |
| Figure 3-23: HLS will prompt to shut down to
 update its configuration. Click OK. Then OK again.  |
Program Help File
RGB Channels (13F)
Introduction to RGB
RGB lighting, both dumb and smart pixels, have added a large amount of complexity and channel counts in displays.  HLS is very advanced in handling RGB channels. This section of the wiki will discuss setting up channels, converting multiple channels into one, and how to use the RGB features for other display items.
Adding RGB Channels
Another example when this may come in handy is when you have imported a sequence from Vixen or LOR which contains three separate RGB channels that you now want to combine into one.
To convert three R, G, B channels into one:
 - Verify that the three channels you wish to convert are setup properly. (See Figure 3-25)
- Open the Converter for RGB (Click Manage Channels -> Auto Convert Channels to RGB. (See Figure 3-26)
- Place the Red Channel in Red, Green Channel in Green, and Blue Channel in Blue. (See Figure 3-27)
- A dialog will open with information about how many channels have been converted. (See Figure 3-28)
- Open HLS and open the Channel Manager to see the newly converted channel(s). (See Figure 3-29)
 - Click OK.
Red, Green, and Blue "mega strings" aren't the only grouped strings that can benefit from the RGB single channel conversion. If your colors are different from those, you can still use the RGB channel to reduce channel count by 2/3. As an example, imagine a Mega tree with 16 strings of red, white, and blue lights (48 strings total). If those mega strings were converted to single RGB channels, the channel count would go from 48 to 16.
- Follow the conversion steps above to convert the multiple channels into RGB channels. Except this time, Red goes to red, WHITE goes to green, and Blue goes to blue.
 - When programming, use red effects for the red lights, blue effects for blue lights, and GREEN effects to control the white lights.
 - If you program white in the RGB channel, then all three colors (red, white, and blue) would be on.
 - Think of the RGB string as three channel control rather than only red, green, and blue control.
Configuring Display Groups (13F)
Introduction to Display Groups
Display Groups are one of the most powerful features of HLS.  It is important to understand what they are and the purpose they serve.  In basic terms, a Display Group is a group of channels that will be displayed in the main sequencing window so you can "work" with them (i.e., add effects, etc.). Channels can be contained in more than one Display Group.  Groups make it possible to show and work with a subset of the channels.
- Note: Display Groups are NOT the same as Preview Groups. Display Groups DISPLAY channels in the sequencing window. Preview Groups are used with the PREVIEW window to help visualize how channels will be physically represented in the display.
Some examples of how Display Groups can be used:
- Global Grouping:
- All: A group containing every channel.
 - Display Object Grouping:
- MegaTree: A group containing all of the MegaTree channels.
 - Roofline: A group containing the roofline channels.
 - Arches: A group containing the channels used in arches.
 - Windows: Group containing windows.
 - Physical Location Grouping:
- House: All channels on the house.
 - Yard: All channels in the yard.
 - Left, Middle, and Right: Three groups that could be setup to break the display into left, middle, and right sides.
 - Color Grouping:
- Red, Green, Blue, and White: Groups could be setup to work with specific colors.
 - These are just SOME examples of how groups could be used. Your imagination is the limit!
Assigning Channels to Display Groups
To begin working with groups, first, channels must be assigned to a Display Group.
- Click Manage Channels -> Select Channels and Assign to Display Group. (See Figure 3-30)
- The Select Channels to Work On screen will appear (See Figure 3-31).
- Select the channels you wish to assign to your group by clicking and dragging to highlight the channels.
 - Click on the Check button to place a checkmark in the Work column. You are telling HLS which channels you want to "work" on.
 - Type in a Name for your new Display Group in the lower right-hand text field and select Save Changes. (See Figure 3-32)
 - Note: You can also choose channels individually to include in a group by manually clicking the Work checkbox for each channel.
Select a Display Group to Work On
To display the newly created Display Group, HLS needs to know that you want to work on it.
- Select Manage Channels -> Select Display Group to Work On. (See Figure 3-33)
- Figure 3-34 will appear. Select the Display Group you wish to work with and click OK.
- The Sequence editor window will appear and the channels in your Display Group will now be ready for work (See Figure 3-35).
Managing Display Groups
To add a new display group:
 - Figure 3-36 will appear. Click New to create a new display group.
 - Follow directions above to select channels.
To remove a display group:
 - Highlight the Display Group you wish to remove and Press Delete.
To Modify a Display Group:
 - Highlight the Display Group you wish to modify and select OK.
 - The Select Channels to Work On window will appear showing all channels in the group.
 - Click Modify List to display all other channels.
 - Check and Un-Check the Work column to add or remove channels from the Display Group.
 - When done, click Save Changes.
Sticky Channels (13F)
HLS allows the user to set up to three "Sticky Channels".  These are channels that can be displayed at the top of the sequencing window (in place of the Audio Oscilloscope).  They maintain their position when scrolling through channels in your sequence.  This can be useful in setting beat tracks that are always at the top or for lining up sequencing effects with another channel.
VIDEO: Joe describes sticky channels in his 2013 Intro video
To Set Sticky Channels:
- Click Manage Channels -> Manage Sticky Channels.
 - This will open the Manage Sticky Channels window which will show all of your channels (See Figure 3-37).
- To set a channel as a Sticky Channel, Click in the Order column next to the channel name and enter a number (1-3). (See Figure 3-38)
 - Once you have numbered the Sticky Channels, Select OK.
- To toggle between Sticky Channels and the Audio Oscilloscope, click Audio File -> Show Sticky Channels (See Figure 3-39).
- The Sticky Channels will now be at the top of the screen (See Figure 3-40).
Segment Channels (13F)
Segment channels allow you to assign multiple channels to a single HLS Channel. As you add effects, modify them, or delete them on the segment channel, all the channels in that segment are affected. Segments add some macro control of your display elements and are especially useful for pixels or face animations.
VIDEO: Joe describes Segment Channels and gives examples of their use in his 2013 Intro video
Examples:
- Multiple pixels or channels assigned to mouth movements.
 - An arch of pixels, with groups of pixels assigned to segments.
 - Assigning a specific color of channels that are on mini-trees to one segment.
Creating Segments for Existing Channels:
- Open the Segment Channel Manager (Manage Channels -> Manage Segment Channels).
 - Figure 3-41 will appear. Click New to create a new Segment.
 - Figure 3-42 will appear. Select the channels you wish to assign to a segment, click "check", name the segment, and click OK.
 - Continue to add segments as needed.
 - Tip: You can also rename segments through the Segment Channel Manager (as of 16K).
Assign Segments to a Display Group:
- Create a new Display group, but only add the newly created segments to the group.
 - Note: The Segment Channels will appear with a green color. See Figure 3-43.
 - Name the group.
 - Set the group to Display in the sequencing window.
 - Add effects to the segments, which will show up in all channels contained in the segment.
Out of Sync Effects:
- If a channel composed in a segment already has effects in cells, those points will be "grayed out" in the Segment view.
 - You will be unable to modify those effects in the Segment view. This protects those effects from being damaged while editing a full segment.
 - To be able to adjust the entire segment area, you must set the display group to view the channel(s) that contain effects at that point in time and remove them.
 - Once you have applied effects in segments, you can go back in to the individual channels and adjust them if needed.
Video:
