Renard PX1 Pixel Controller
General
Features
- Standard Renard connections
 - 5VDC and 12VDC operation
 - WS2801 and WS2811 pixels
 - Some Design Details:
- One output (same 3.5mm connector and pinout as jstjohnz's controller), handling up to 200 pixels
 - RS485 input, same RJ45 pinout and protocol as Renard controllers
 - 115200 input baudrate (lower rates provided, but not recommended)
 - Uses PIC16 parts, so existing programmers should work.
 - Supports WS2811 strings at with either 400KHz or 800 KHz data rate, 5V or 12V power input
 - Uses external 5V supply (readily available from Ebay, China, etc).
 - Power, RxD and FE (framing error) indicators
The number of Pixels that can be supported per serial port depends on both the baud rate and on the frequency of updates that has been programmed into the Vixen sequence. The most common PC control software is Vixen, which easily supports multiple serial ports (including USB-RS232 and USB-485 converters).
| Total Number of Pixels Capable  for a given Baud Rate/Refresh Interval*  | |||
| 100 ms | 50 ms | 25 ms | |
| 460800 | 800 | 764 | 382 |
| 230400 | 400 | 382 | 191 |
| 115200 | 200 | 191 | 95 |
| 57600 | 191 | 95 | 47 |
| 38400 | 127 | 63 | 31 |
| 19200 | 63 | 31 | 15 |
The Vixen 2.x Plugin for Renard supports baudrates up to 115200. A new plugin is required to support higher baudrates.
Typical Pixels require power injection every 50 pixels.  The Renard PX1 only supports up to 50 Pixels directly powered from the controller.  If you use more then 50 Pixels, you must provide an off board fused power source to provide power injection downstream.
PCB Layout
BOM - Bill Of Materials
| R6 | 260-680-RC | Resistor Network, 680 Ohm, Bussed, 6-pin | 1 | |
| C1 | 810-FK28X5R1C105K | Multilayer Ceramic Capacitors MLCC - Leaded 1.0uF 16volts X5R +/-10% | 1 | |
| J4 | 649-77313-122-10LF | Headers & Wire Housings 10P STR DR TMT HDR .76 AU .526IN LENGTH | 1 | |
| J9 | 571-2828372 | Fixed Terminal Blocks 5.08MM PCB MOUNT 2P | 1 | |
Assembly Instructions
 - Configure Jumpers
- Begin by inspecting the PCBs to look for any defects such as cracks or breaks.  The holes on the board should be open on both sides.  Then inspect and sort out the various parts for the boards.
- Install Resistors
 - Install Capacitors
 - Install Diodes
 - Instal IC Sockets
 - Install LEDs
 - Install Headers. The short end of the header is soldered into the PCB.
 - Install Voltage Regulator
 - Install Connectors
 - Install Fuse Holder
 - Install ICs
- Install the 14 pin PIC in
 - Install the 8 pin RS485 chip in
Configure Jumpers
- J3- 1x2 DMX Termination Resistor
 - J4- 2x5 Options Connector
 - J5- 1x2 RS232
 - J7- 1x2 Programing?
 - J8- 1x3 5V Bypass
Connections
J1 and J2-Renard Input and Output
NEEDS WORK
The two RJ45 Connectors J1&J2 near the top of the board are used to bring data signals to and from the board.  The pins on these connectors are used as follows:
| Pin # | RJ45 Connector | |
| J1 | J2 | |
| 1,2 | GND | GND |
| 3 | NC | NC |
| 5* | Data+ (Rx) | Data+ (Tx) |
| 6,7,8 | NC | NC |
- This pin is connected to GND through J3 if a shunt is installed in J3.
J6-ICSP Programming Header
NEEDS WORK
J6 is the 6 pin header located in the top center of the board.  J6 allows the PIC microprocessor to be programmed in place on the board by directly connecting a PICKIT2 or PICKIT3 programer.
Pin 1 is the square hole towards the left side of the board closest to D1.
J9-Power
J9 is the 2 pin terminal block located at the bottom left side of the PCB.  The Renard PX1 can be powered by either 5 or 12VDC (depending on pixel type).  If you are using 5VDC, you can omit the voltage regulator and set Jumper J8 to the bypass position.If you are using 12VDC, then you must use the on board voltage regulator.
| J9 Power Input | ||
| Pin # | ||
| Voltage | ||
| 1 (square pad on left) | GND | |
J10(4 pin)- Output to Pixels
J10 is located along the bottom right side of the board and is a 4 pin Euro style plugable connector used to connect to the Pixels.  Pin1 of the connector is on the left side and is marked by the square hole on the silkscreen.
| J10 Pixel Output Pin Assignments | ||
| Pin # | ||
| Signal | ||
| 1 | GND | |
| 2 | Clock | |
| 3 | Data | |
| 4 | V+ | |
Enclosure
DIYC Flood Discussion Threads
