Part Substitutions
IC Chips
| SN65LBC176AP | Differential Bus Transceivers | SN65LBC176PE4 511-ST485BN 595-SN65176BP |
Renard 16 Renard 24 Renard 64 Renard SS |
| 579-PIC16F688-I/P | PIC Microcontroller | 579-PIC16F688-E/P | Renard 16 Renard 24 Renard 64 Renard SS |
| 782-H11AA1 | Optocoupler, Bi-Directional Input | Renard 16 Renard 24 Renard SS | |
| 859-MOC3023 | Optoisolator, Triac Driver | Renard 16 Renard 24 Renard SS SSRez | |
| 571-1-390261-2 | IC Socket, 8 pin (for U1 & U2) | 575-193308 | Renard 16 Renard 24 Renard 64 Renard SS |
| 571-1-390261-3 | IC Socket, 14 pin (for U3–U5) | 575-199314 | Renard 16 Renard 24 Renard 64 Renard SS |
| 571-1-390261-1 | IC Socket, 6 pin (for U8–U31) | Renard 16 Renard 24 Renard 64 Renard SS SSRez |
Voltage Regulators
| 821-TS7805CZ | 5VDC Voltage Regulator | 511-L7805CV | Renard 16 Renard 24 Renard 24LV |
| 511-L4940V5 | Regulator, LDO, 5V, 1.5A | Renard 64 | |
| 511-LF50CVDG | Regulator, LDO, 5V, .5A | 511-LF50CV (Basically the same item but with a thinner tab, so care needs to used when installing the heatsink) |
Renard SS |
| 532-574502B00 | Heatsink for Voltage Regulator | Renard 16 | |
| 532-577102B00 | Heatsink for Voltage Regulator | Renard SS | |
| 532-7136DG | Heatsink for Voltage Regulator | 532-7139DG | Renard 24 Renard 24LV |
Diodes, LEDs, Triacs
| 78-1N5239B | Diode, Zener 9.1V .5W | 78-1N5239B-TAP | Renard 16 Renard 24 Renard 24LV Renard 64 Renard SS |
| 78-1N5229B | Diode, Zener 4.3V .5W | 78-1N5229B-TAP 512-1N5229B_T50A |
| 604-WP63ID | LED, 5mm Red | Any standard 3mm or 5mm LED will work | Renard 24 Renard 24LV |
| 604-WP1503GD | LED, 5mm Green | Any standard 3mm or 5mm LED will work | Renard 24 Renard 24LV |
| 604-WP7104EC | LED, 3mm Red | Any standard 3mm LED will work | Renard 16 |
| 604-WP710A10IT | LED, 3mm Red | Any standard 3mm LED will work | Renard SS |
| 604-WP710A10GT | LED, 3mm Green | Any standard 3mm LED will work | Renard 16 Renard 64 Renard SS SSRez |
| 859-LTL-403G | LED, Rectangular, Green | 859-LTL-403HR - Red 859-LTL-403Y - Yellow |
Renard 64 |
| 625-1N4001-E3 | Diode | Renard 16 Renard 24 Renard 24LV | |
| 625-1N5817-E3 | Schottky Diode (20V, 1A) | 625-1N5817-E3/4 | Renard 64 Renard SS |
| 821-DB102G | Bridge Rectifier, 1A 100V | DB103 | Renard 24HC Renard 24LV |
| 511-BTA08-400B | Triac, 8A 400V | 511-BTA04-700T Triac, 4A 700V (alternative Triac for use with LED light strands - See "EOL" Note Below) |
Renard 16 Renard 24 |
| 511-BTA04-700T | Triac, 4A 700V Update: Now listed as EOL or "End of Life" |
BTA06-600TRG | SSRez REN24HC |
| 511-BTA04-700T | This triac (the original preferred triac for the Renard SS controllers) is no longer being manufactured and generally no longer available from parts suppliers. This note is included here to provide information on why this triac was replaced for the Renard SS controllers so users will not be concerned about having these triacs in any existing Renard SS controllers. |
Renard SS | |
| 511-BTA06-600CW | Triac, 6A 600V | Renard SS | |
Resistors
| 291-120-RC | Resistor, Carbon Film 120 ohms 1/4W 5% | 271-120-RC 660-MF1/4DCT52R1200F |
| 291-1K-RC | Resistor, Carbon Film 1K ohms 1/4W 5% | 271-1K-RC 660-MF1/4DC1001F (Renard 24 ZC resistors) |
Renard 24 |
| 299-1K-RC | Resistor, Carbon Film 1K ohms 1/8W 5% | 271-1K-RC 660-MF1/4DC1001F (Incoming data circuit resistors only) |
| 299-27K-RC | Resistor, Carbon Film 27K ohms 1/8W 5% | 271-27K-RC 660-MF1/4DLT52R2702F |
| 291-680-RC | Resistor, Carbon Film 680 ohms 1/4W 5% | 271-680-RC | Renard 24 SSRez |
| 299-680-RC | Resistor, Carbon Film 680 ohms 1/8W 5% | Renard 64 Renard SS | |
| 291-180-RC | Resistor, Carbon Film 180 ohms 1/4W 5% | 271-180-RC 273-180-RC |
| 71-CCF60-15K-E3 | Resistor, Metal Film 15K ohms 3/4W 1% | Renard 16 | |
| 291-750-RC | Resistor, Carbon Film 750 ohms 1/4W 5% | 660-CFS1/4CT52R751J | Renard SS |
| 299-750-RC | Resistor, Carbon Film 750 ohms 1/8W 5% | Renard 64 | |
| 299-330-RC | Resistor, Carbon Film 330 ohms 1/8W 5% | Renard 64 | |
| 266-680 | Resistor Network, 10 pin, 680ohms 2% | Renard 16 | |
| 264-330 | Resistor Network, 6 pin, 330ohms 2% | Renard SS | |
| 652-4608X-1LF-680 | Resistor Network, 8 pin, 680ohms, Bussed 2% | Renard 64 |
Capacitors
| 81-RPEE41H105M4K1E12 | Capacitor, Monolithic Radial Lead 50V 1uF | Renard 16 | |
| 80-C410C104M5U | Capacitor, Axial Ceramic 50V 0.1uF | Renard 16 | |
| 581-SA105E104MAR | Capacitor, Axial Ceramic 50V 0.1uF | Renard 24 | |
| 140-HTRL25V10-RC | Capacitor, Electrolytic 25V 10uF 105°C | Renard 24 | |
| 140-XRL25V1.0-RC | Capacitor, Electrolytic 25V 1uF 85°C | Renard 24 | |
| 667-ECA-1CM682 | Capacitor, Electrolytic 16V 6800uF 85°C | 140-REA682M1CBK1632P 140-XRL16V6800-RC (EOL) |
Renard 64 |
| 140-REA470M1CBK0511P | Capacitor, Electrolytic 16V 47uF 85°C | 647-UVR1C470MDD1TD 647-UVR1C470MDD1TA |
Renard SS |
| 140-REA222M1CBK1320P | Capacitor, Electrolytic 16V 2200uF 85°C | 647-UVR1C222MHD1TO 871-B41827A4228M000 |
Renard SS |
| 80-C322C104K5R | Capacitor, Radial Ceramic 50V 0.1uF | Renard 64 Renard SS | |
| 667-ECA-1CM470 | Capacitor, Electrolytic 16V 47uF 85°C | 75-515D476M016JA6AE3 | Renard 64 |
Other
| 838-3FD-320 | Transformer, Dual Primary/Secondary | 838-3FD-316 | Renard 24 |
| 838-3FS-312 | Transformer, Single Primary/Dual Secondary | Renard SS | |
| 520-TCF1843-X | Crystal Clock Oscillator, 18.432 MHz (full size) | ACO-18.432MHZ-EK | Renard 24 |
| 815-ACH-18.432-EK | Crystal Clock Oscillator, 18.432 MHz (half size) | 520-TCH1843-X | Renard 16 Renard 64 Renard SS |
| 538-22-03-2021 | Header, 2-Pin PCB | 538-22-28-4360 Header, 36 Pin Breakaway (used to make smaller headers) |
| 538-22-03-2031 | Header, 3-Pin PCB | Renard 24 | |
| 737-MSA-G | Shunt | 571-3828115 | Renard 16 Renard 24 Renard 64 Renard SS |
| 504-GMA-10 | Fuse, Fast Acting 10A 125VAC | Renard SS | |
| 504-GMA-15 | Fuse, Fast Acting 15A 125VAC | Renard 16 Renard 24 | |
| 504-1A3399-10 | Holder, Fuse Clip PCB mount 5mm | Renard 16 | |
| 534-3517 | Holder, Fuse Clip PCB mount 5mm | Renard 24 Renard SS SSRez | |
| 534-3527C | Cover, Fuse Clip | Renard SS | |
| 571-5556416-1 | Jack, Modular RJ45 PCB Mount Top Entry | 571-55202594 538-95503-2881 |
| 571-5520251-4 | Jack, Modular RJ45 PCB Mount Side Entry | Renard 16 Renard 64 SSRez | |
| 636-182-009-213R531 | Connector, D-Sub Female, Rt Angle PCB mount, DE9` | Renard 64 | |
| 152-3409 | Connector, D-Sub Female, Rt Angle PCB mount, DE9` | Renard SS | |
| 538-39890-0302 | Terminal Block, 2 Pos 5.0 mm | Renard 16 | |
| 571-2828372 | Terminal Block, 2 Pos 5.08 mm | Renard SS SSRez | |
| 571-7969492 | Terminal Block, 2 Pos (Input Power) | 158-P02EHK508V2-E | Renard SS |
| 571-7969494 | Terminal Block, 4 Pos (Input Power) | Renard 24 | |
| 571-2828376 | Terminal, 6 Pos | Three of 571-7969492 | Renard 24 Opt#1 |
| 651-1725041 | Terminal, Dbl Stack 4 Pos | Renard 24 Opt#1 | |
| 534-1287 | Terminal, Spade | Renard 24 Opt#2 | |
| 534-4902 | Male Sturdi-mount Terminal | Renard 64 | |
| 159-2215 | Vinyl Insulated Couplers (Female) | Renard 64 |
