Renard PX1 Pixel Controller
General
The Renard PX1 was designed by Phil Short as an inexpensive Pixel controller designed to work with standard Renard systems. It can be daisy chained with other Renard controllers.
The design consists of a controller board with a PIC16F1825PIC microcotroller that connects via a simple RS485 connection protocollike all Renard controllers. The PX1 Controller is capable of driving up to 200 pixels per controller (with power injection after the 50 pixel) or 50 pixels directly. It supports both 12VDC and 5VDC pixels. The PX1 Controller is designed to support pixels that use the WS2811 and WS2801 IC.
Features
- Some Design Details:
- Supports up to 50 pixels from the onboard power connection
- Uses PIC16 F1825 microprocessor, so it can be programed with traditional PICKIT 2 or PICKIT 3 programmers.
- Supports WS2811 strings at with either 400KHz or 800 KHz data rate
- Power, RxD (recieving data), FE (framing error)and Attn LED status indicators
Total Number of Pixels Capable for a given Baud Rate/Refresh Interval* | |||
Baud Rate | Refresh Interval | ||
100 ms | 50 ms | 25 ms | |
460800* | 1528 | 764 | 382 |
230400* | 764 | 382 | 191 |
115200 | 382 | 191 | 95 |
57600 | 191 | 95 | 47 |
38400 | 127 | 63 | 31 |
19200 | 63 | 31 | 15 |
PCB Layout
BOM - Bill Of Materials
Part | Mouser PN | Description | Qty |
R6 | 291-120-RC | Carbon Film Resistors - Through Hole 120ohms 0.05 | 1 |
R5,R7 | 299-1K-RC | Carbon Film Resistors - Through Hole 1Kohms 5% | 2 |
R1,R2 | 299-27K-RC | Carbon Film Resistors - Through Hole 27Kohms 0.05 | 2 |
R4 | 264-680-RC | Resistor Network, 680 Ohm, Bussed, 6-pin | 1 |
R3,R8 | 299-47-RC | Carbon Film Resistors - Through Hole 47ohms 0.05 | 2 |
C2,C3 | 810-FK28X5R1C105K | Multilayer Ceramic Capacitors MLCC - Leaded 1.0uF 16volts X5R +/-10% | 2 |
C1 | 80-C322C104K5R | Multilayer Ceramic Capacitors (MLCC) - Leaded 50volts 0.1uF 10% X7R | 1 |
D1 | 78-1N5239B | Diode, Zener 9.1V .5W | 1 |
D2 | 78-1N5229B | Diode, Zener 4.3V .5W | 1 |
D3,D4 | 604-WP710A10IT | LED, 3mm Red | 2 |
D5,D6 | 604-WP710A10GT | LED, 3mm Green | 2 |
IC1 | 595-SN65LBC179PE4 | Buffers & Line Drivers | 1 |
IC2 | 579-PIC16F1825-I/P | Microcontroller | 1 |
IC3 | 926-2950CZ-5.0/NOPB | LDO 5.0/100mA | 1 |
U1 | 571-1-390261-2 | IC & Component Sockets 8P ECONOMY TIN | 1 |
U2 | 571-1-390261-3 | IC & Component Sockets 14P ECONOMY TIN | 1 |
J5,J6 | 571-5556416-1 | Jack, Modular RJ45 PCB Mount Top Entry | 2 |
J4 | 538-22-03-2021 | Headers & Wire Housings VERT PCB HDR 2P TIN PLATING | 1 |
J3 | 649-77313-122-10LF | Headers & Wire Housings 10P STR DR TMT HDR .76 AU .526IN LENGTH | 1 |
J2 | 538-22-03-2061 | Headers & Wire Housings VERT PCB HDR 6P TIN PLATING | 1 |
J1,J7 | 538-22-03-2031 | Headers & Wire Housings VERT PCB HDR 3P TIN PLATING | 2 |
J8 | 571-2828372 | Fixed Terminal Blocks 5.08MM PCB MOUNT 2P | 1 |
Jumpers | 151-8000-E | Headers & Wire Housings MINI JUMPER GF 6.0MM OPEN TYPE BLACK | 7 |
J9 | 538-39501-6004 | Pluggable Terminal Blocks 3.5MM EURO HEADER VE HEADER VERT GRN 4CKT | 1 |
Pixel Connector | 538-39503-2004 | Pluggable Terminal Blocks 3.50MM EURO PLUG VER UG VERT RWE BLK 4CKT | 1 |
Fuse | 504-ATM-5 | Fuses 5A 32Vdc 1kA IR Tan | 1 |
Fuse Holder | 534-3544-2 | Fuse Holder | 1 |
Assembly Instructions
- Configure Jumpers
- Program PIC
- □ Install Resistors
- □ R4 - 680 ohm bussed resistor. Note that this resistor is polarized and only can go in one way. The dot on the package denotes pin1.
- □ Install Capacitors
- □ Install Diodes
- □ Instal IC Sockets
The notch faces right. - □ U2 - 14 pin socket. The socket has a notch on one end and the notch must be installed to match the direction on the silkscreen.
The Notch faces right.
- □ Install LEDs
- □ D3,D4 - Red LED. LEDs are polarized and they have to be installed with the correct orientation. The anode side of the LED with the longer leg goes in the top round hole.
- □ Install Voltage Regulator
- □ Install Fuse Holder
- □ Install Connectors
- □ Install RJ45 Jacks
- □ Install Fuse
- □ Install ICs
The IC has a notch on one end and the notch must be installed to match the direction on the silkscreen. - □ IC2 - PIC16F1825-I/P PIC microprocessor. The IC is polarized and it has to be installed with the correct orientation.
Configure Jumpers
Install a jumper across Pin 1 and Pin2 if you are using RS232 Input to the controller. Install a jumper across Pins 2 and Pin 3 if you are using regular RS485 input.
J3- 2x5 Options Connector
J4- Programing?
J7- 5VDC Regulator Bypass
This 3 pin jumper is used to select the power source of the control circuit on the board. If the power input to the board is 12VDC, then jumper must be placed on the two left pins. If the power input to the board is 5VDC, then the jumper must be placed on the right two pins.
Program PIC
Connections
Serial Data Connector Pin Assignments | ||
Pin # | RJ45 Connector | |
J5 Input | J6 Output | |
1,2 | GND | GND |
3 | NC | NC |
4 | Data- (Rx) | Data- (Tx) |
5 | Data+ (Rx) | Data+ (Tx) |
6,7,8 | NC | NC |
J2-ICSP Programming Header
J2 is the 6 pin header located in the top center of the board. J2 allows the PIC microprocessor to be programmed in place on the board by directly connecting a PICKIT2 or PICKIT3 programer.
J2 ICSP Pin Assignments | ||
Pin # | ||
Signal | ||
1 | VPP/MCLR | |
2 | VDD Target | |
3 | VSS (Ground) | |
4 | ICSPDAT/PGD | |
5 | ICSPCLK/PGC | |
6 | N/C |
J8-Pixel Power Input
J8 is the 2 pin terminal block located at the bottom center of the PCB. The Renard PX1 can be powered by either 5 or 12VDC (depending on pixel type). If you are using 5VDC, you can omit the voltage regulator and set Jumper J7 to the 5v position.If you are using 12VDC, then you must use the on board voltage regulator and set Jumper J7 to the 12v position.
J8 Power Input | ||
Pin # | ||
Voltage | ||
1 (square pad on left) | GND (V-) | |
2 (round pad on right) | V+ |
J9 - Output to Pixels
J9 Pixel Output Pin Assignments | ||
Pin # | ||
Signal | ||
1 | GND (V-) | |
2 | Clock (C) | |
3 | Data (D) | |
4 | V+ |
Indicator LEDs
Attn
Rx
FE
Pwr
- Baud Rate: Allows you to set the controller to match the speed of your existing Renard network.
- Number of Pixels: Allows you to set the specific number of pixels to be attached to controller (1-200)
- RGB Order: Allows to make corrections for strings where the pixels respond in a different color order UNDER DEVELOPMENT
- Grouping: Allows you to treat multiple pixel as one pixel, cutting down on the number of channels used. UNDER DEVELOPMENT
Enclosure
