Assembly Instructions For The REN 32
Board Assembly
- The following sequence of steps is by no means the only way to assemble the Ren32. It is simply a suggested order of events to achieve the desired goal. You can click on any photo for an enlarged view of that photo.
- NOTE: The part numbers referenced in the following instructions are those taken from the REN 32 BOM.
- JP1 & JP2 Configuraton
- JP1 installed
- JP2 not installed
- JP1 not installed
- JP3 Configuraton
Mounting the REN 32 in an Enclosure
- The REN 32 has mounting holes that line up with the standoffs in the common enclosures like the CG-500, CG-1000 and the CG-1500.
Parts Listing (BOM)
IMPORTANT BOM INFORMATION:
QTY | REF | NOMENCLATURE |
| 815-ACH-18.432-EK | 1 | U3 | Crystal Clock Oscillator, 18.432 MHz |
| 579-PIC16F688-I/P | 4 | U6-U9 | PIC Microcontroller |
| 571-1-390261-3 | 4 | IC Socket, 14 pin (for U6-U9) | |
| 571-1-390261-1 | 1 | IC Socket, 6 pin (for U2) | |
| 299-680-RC | 1 | R6 | Resistor, Carbon Film 680 ohms 1/8W 5% |
| 625-1N5817-E3 | 4 | D1-D4 | Diode |
| 604-WP710A10IT | 2 | FE, OE | LED, 3mm Red |
| 604-WP710A10GT | 4 | PWR, HB, ZC, SD | LED, 3mm Green |
| 140-REA222M1CBK1320P | 1 | C1 | Radial Electrolytic Capacitor 16V 2200uF 20% |
| 140-REA470M1CBK0511P | 1 | C2 | Radial Electrolytic Capacitor 16V 47uF 20% |
| 80-C322C104K5R | 4 | C3-C6 | Capacitor, Radial Ceramic 50V 0.1uF |
| 571-7969492 | 1 | Power Terminals | Terminal Block, 2 Pos 5.08 mm |
| 571-5556416-1 | 10 | J1-J10 | Jack, Modular RJ45 PCB Mount Top Entry |
| 737-MSA-G | 3 | Shunt | |
| 504-GMA-10 | 1 | F1, F2 | Fuse, Fast Acting 10A |
| 534-3517 | 2 | Holder, Fuse Clip PCB mount 5mm | |
| 534-3527C | 1 | Cover, Fuse | |
| 838-3FD-412 | 1 | TF1 | Power Transformers 12.6VAC CT 6.0VA Dual Primary |
Hardcopy Instructions
- Board Availability Information]
