Generally pixels come from vendors without connectors attached or they have proprietary non waterproof connectors connected to them. Most people utilize some form of water resistant connectors attached to their pixels and the mating connector to their pixel controllers. It is common to install the female connector (socket end) to the power source (controller) and the male connector( plug end) to the pixel string. Some people also use dielectric grease or protective spray like CorrosionX to further prevent corrsion and oxidation of the electrical contacts due to moisture.
Connectors from different vendors generally do not fit together due to different manufacturers sizes and keying.
Types of Pixel Connectors
Euro Connector
These connectors are typically found on pixel controllers like the Sandevices E682 of the Renard PX1. They are polarized and the plug only fits in the socket one way.
Euro Female socket
Because the plug and socket are polarized it is critical that you connect the wires correctly to the controller and the pixels. The wire order for the typical E682 pixel controller is:
E682 Pixel Output Pin Assignments | ||
Pin # | ||
Signal | ||
1 | GND (V-) | |
2 | Clock (C) | |
3 | Data (D) | |
4 | V+ |
Euro Male Plug
The male plug is generally attached directly to the pixels or may be connected to a pigtail. They can also be purchased from Mouser in two versions, one with an inline wire entry like used on the Sandevices E682 and one with a rear wire entry as used on the Renard PX1
Pigtails
These are typically connected to the end of the pixel strings .
Tee
Often used for power injection.
Extension cable
Caps
These typically go on unused male pigtail ends to seal them from the weather.
Wire Sizing
It is desirable to use the largest wire diameter (smaller wire gauge) that you can when connecting your pixels to your controller. The smaller wire gauge results in a high voltage drop and can cause your pixels to have poor colors or to not function at all. This is a good thread that discusses voltage drop.
This is a Voltage Drop Calculator useful for calculating the effects of different wire sizes and lengths on pixel strings.
Wire Sizing | ||
Wire Gauge (AWG) # | ||
Cross section Area (mm2) | ||
14 | 2.08 | |
16 | 1.31 | |
18 | 0.823 | |
20 | 0.518 | |
22 | 0.328 |
These are selected connectors from the various vendors with a mix of properties. Visit their sites for the latest information and to see their entire product catalog. Many of the vendors can provide custom length wires on the pigtails.
Ray Wu
(China Based)
Type | Color | Conductors | Length | Diameter | Link | Image | Quantity | Price | Price per Connector | Note |
Cap | White | 13.5mm | link | 10 | $0.50 | $0.05 | End cap to go on unused male plugs | |||
Cap | Black | 13.5mm | link | 10 | $0.50 | $0.05 | End cap to go on unused male plugs | |||
Pigtail | White | 2 | 20cm | 13.5mm | link | 10 | $3.00 | $0.30 | 2x0.5mm²wire | |
Pigtail | Black | 2 | 15cm | link | 50 | $23.16 | $0.46 | |||
Pigtail | Clear | 2 | 10cm | link | 100 | $57.89 | $0.58 | Coaxial 5.5/2.1mm 22gauge wire | ||
Extension | White | 2 | 1.5m(5feet) | link | 10 | $10.00 | $1.00 | 2x0.5mm² wire | ||
Extension | White | 2 | 3m(10feet) | link | 10 | $16.00 | $1.60 | 2x0.5mm² wire | ||
Tee | White | 2 | 40cm | 13.5mm | link | 10 | $17.00 | $1.70 | 2x0.5mm² wire | |
Tee | Black | 2 | 40cm | 15mm | link | 1 | $2.20 | $2.20 | 2x0.75mm² wire |
