E68X-to-DMX
E68X-to-DMX Adapter
E68XTODMX Schematic
Bill of Materials
Here is the current BOM for the adapter
Board Layout
E68X-DMX Schematic
E68XTODMX KIT 1 CONTENTS
E68XTODMX KIT1 CONTENTS
E68XTODMX KIT 2 CONTENTS
E68XTODMX KIT2 CONTENTS
E68XTODMX PCB
E68XTODMX PCB
Install the 120 ohm resistor - there is no polarity
Install a wire jumper instead of the 7805 regulator if you are using 5v pixel power - do NOT install if using 12v pixel power
Install the three 100nF decoupling capacitors - there is no polarity
Install the 8-pin DIP Socket
Install the two 2x3 headers horizontally
Install the four shunts - all four on left for DMX or all four on right for Renard output wiring
If you are not using the 4-pin terminal block, take four pieces of wire and bend the ends over as shown
Insert the wires and solder them in
Here are the four wires shown from the bottom
Trim the four wires to about 1/2" or so
Insert the four wires into the Terminal Block provided from your E681
Install the RJ45 connector
Completed E68XTODMX Adaptor (5v version)
If you are using 12V Pixel power, install the 7805 regulator
If you are using the 4-pin terminal block, install it now
E68x Configuration
  • Pixel Type of "DMX PIXEL" - use the command CH X,5 where X is the Group number
  • String Count of 1 - use the command ST X,1 where X is the Group number
  • Pixel Count of 170 - use the command PI X,170 where X is the Group number
The converter must be plugged into the first connector of the group (1-1, 2-1, 3-1 or 4-1) if you want a full universe (actually 510 channels).
You can also get creative and configure it with 4 strings of up to 42 pixels and use all four connectors in a group and you will end up with four separate DMX streams starting at addresses of 1-126, 127-252, 253-378 and 379-504. Smaller string lengths will result in smaller bundles of DMX addresses. Note that all strings sizes have to be the same length for a given group. Also remember the unit of measurement is pixels or 3-channels - not single channels.
Converter Configuration
The four jumpers must be placed all on the left for DMX wiring or all on the right for Renard wiring. You must install all four of the jumpers or install wire jumpers instead for the converter to work properly.
If you are using 5v pixel power on the connector you can jumper out the 78L05 regulator to provide 5v power. If you are using 12v pixel power then be sure to NOT have the bypass jumper installed or it will fry the RS485 chip. It is not recommended to use this board with 24v pixels as it may cause the regulator to overheat.
