10W-RGB-LED-DRIVER
![Version G2](/wiki/images/8/86/10W_RGB_Driver_Top.jpg)
It has the ability to drive a 10W RGB LED via a 5v DC PWM signal that will therefore allow
As a separate 12V power source is applied to the board, three additional connections are made to the board that can
10W RGB LED
![small](/wiki/images/9/96/10W_RGB_LED_smaller.jpg)
This board was specifically designed for a commonly found 10W RGB LED.
Color: RGB
Beam Angel: 140 degrees
Life span: >50,000 hours
less than 1" square.
BOM for 12V DC power input:
QTY Board ID Description 3 IC1,IC2,IC3 PT4115 by Powtech: 30V, 1.2A Step-down High Brightness LED Driver with 5000:1 Dimming 3 L1,L2,L3 100uH Inductor, 6x8mm, 700ma 3 T1,T2,T3 Transistor FJN3314R 3 D1,D2,D3 Diode 1N5819 3 R1,R2,R3 Resistor, 1/4 Watt, 0.33 Ohm, 5% or better, carbon or metal film 3 R4,R5,R6 Resistor, 1/4 Watt, 4.7K (4K7) Ohm, 5% or better, carbon or metal film 1 IC4 Voltage Regulator, 5V 78L05 1 C1 Electrolytic Capacitor 100uF 35v (polarized) 1 C2 MLCC Ceramic Capacitor .1uF 50v (monolithic)
Assembly Tips
This board had only one part that will take some small amount of skill to install, the PT4115.
Mounting Examples
Here are some different examples of mountings in repurposed LED flood lights
