ESPixel Stick & ESPixel Pops
![Version V2](/wiki/images/c/c3/Pixel_Pops_Picture.jpg)
The ESPixel Pops is a variation of the original ESPixel Stick
The ESPixel Pops is the most basic of the Pixel Stick designs. It is a fully through hole PCB with no smd(surface mount) components. Therefore, it is easily built by most anyone with basic soldering skills
![small](/wiki/images/c/c3/Pixel_Pops_Picture.jpg)
1. A
2. B
3. C
4. C
Order your own boards
Since there is no onboard fuse, if a power overload should occur, the ESP-01 or the ESPixel Pops board may be damaged. You can add an inline fuse if desired inline with the input power feed.
BOM for 120VAC Operation:
QTY Mouser #: Description 2 606-A9A Neon Lamp 65VAC .7mA NE-2E marked NE1, NE2 (See the note below for an alternative source) 1 571-5556416-1 Modular Jacks 8 PCB TOP ENTRY marked J1 4 511-BTA04-700T Triacs 4 Amp 700 Volt marked U1, U2, U3, and U4 OR 511-BTA06-600S Triacs 6 Amp 600 Volt marked U1, U2, U3, and U4 2 534-3517 Fuse Clips and Holders PC FUSE CLIP 5 MM 1 534-3527C Fuse Cover 5 604-WP7104IT LED Standard HI EFF RED TRANS marked LED1, LED2, LED3, LED4, LED5 1 660-CF1/4C681J 1/4Watt Axial Carbon Film Resistors 680ohms 5% marked R9 4 660-CF1/4C221J 1/4Watt Axial Carbon Film Resistors 220ohms 5% marked R1, R2, R3, R4 4 660-CF1/4C181J 1/4Watt Axial Carbon Film Resistors 180ohms 5% marked R5, R6, R7 & R8 2 660-CF1/4C104J 1/4Watt Axial Carbon Film Resistors 100Kohms 5% marked R10, R11 4 859-MOC3023 Optocomponents Optocoupler marked IC1, IC2, IC3 and IC4 4 571-1-390261-1 IC Sockets 6P ECONOMY TIN marked IC1, IC2, IC3, IC4 5 571-2828372 Terminal Blocks 5.08MM PCB MOUNT 2P marked TB1, TB2, TB3, TB4, TB5 Note regarding resistors. You usually want to purchase resistors from Mouser in quantities of 100 of a specific value. You usually can get 100 resistors for the same price of 20 individual resistors. (You will eventually use them !) As noted above in the FUSE Section, you have a choice to make. You only need one fuse per SSRneon. You should always order extra fuses. 1 504-GMC-2 5mm x 20mm Medium Time Delay Fuses 125VAC 2A Med Time Delay 1 504-GMC-3 5mm x 20mm Medium Time Delay Fuses 125VAC 3A Med Time Delay 1 504-GMC-4 5mm x 20mm Medium Time Delay Fuses 125VAC 4A Med Time Delay 1 504-GMC-5 5mm x 20mm Medium Time Delay Fuses 125VAC 5A Med Time Delay 1 504-GMC-6 5mm x 20mm Medium Time Delay Fuses 125VAC 6A Med Time Delay 1 504-GMC-7 5mm x 20mm Medium Time Delay Fuses 125VAC 7A Med Time Delay 1 504-GMC-8 5mm x 20mm Medium Time Delay Fuses 125VAC 8A Med Time Delay The following items are NOT available from Mouser. You can get everything but the TA-200 from your local hardware store or home center. See above for TA-200 sources. 2 Screw,#8x1/2" Pan Head Sheet Metal (You can use the screws that come with the TA-200 if you cut them down) 1 TA-200 Enclosure 1 Male Plug Power Cord, Rated for 10A Minimum 4 Female Plug Power Cord, Rated for 4A Minimum The power cords are often fashioned from standard household extension cords with one of the ends cut off. You can also make your own with SPT wire and 'vampire' plugs/receptacles.
Leaving out the LED Channel Indicators
I don't want the LED Indicators !
How to use LEDs of many colors for the Channel Indicators
Red LEDs have a typical forward voltage (Vf) of 2.0 volts. However, other colors, like green, have a Vf of 3.x volts. Therefore, if you use a LED with a Vf in this range, you should replace the 220 ohm resistor connected to that LED with a 180 ohm resistor.
The basic equation is:
V(supply): Supply voltage, in our case 5V
Vf(opto): Forward voltage of the opto emitter, 1.5V max, 1.15 typ
Vf(LED): Forward voltage of the LED, for the LEDs I use it is 2.0V
Vol: Low voltage output level, For the purposes of this calculation, a value of 0.33V max, 0.18V typical was used.
If you are concerned about the current draw then you can increase the value of R based on the typical values (i.e. to either 270 or 300). However, there is a concern that with the temperature extremes these devices are used in, this would push them closer to the max values and cause erratic behavior.
Wiring The SSRneon
Controller Output Pinout
![Version G2](/wiki/images/d/d8/Ssrneong2led.jpg)
